87 CRX Si w/ 1st Gen B16a final drive Q
Old 06-22-2006, 12:38 PM   #26
Blah blah blah....
MikeBergy's Avatar
Rep Power: 49 MikeBergy is on a distinguished road
Send a message via AIM to MikeBergy
Originally Posted by typej
The diameter of the tire affects your final drive as if it was a gear itself. If you looked at Fatboy Raceworks Transmission Gear Ratio Calculator - Honda/Acura & More and put in your stock tire size and say tire size for a drag radial you will notice that each gear will have an increase in speed with the final gear, 5th or 6th, having the most increase, regardless of what your final drive is.
Lol, I'm well aware of how gearing works. I am also well aware that a taller tire is going to effectively give you higher gearing - I am sure that most drag cars are setup with a set of slicks or drag radials that have tried different size tires and found which size works best for their specific application, but was merely noting that most drag cars have bigs slicks for the wrinkle walls- gearing is only a secondary priority.
Still not buying your reasons for lowering your final drive and going with bigger tires. I will tell you now that I have had 205/50-R16s on my integra, and the car was a DOG. I have 205/45-R16s on there now, and the accleration is much better. If I had a crapton of torque, and was drag racing, and was eating 205/45-r16s for breakfast because I couldn't get any traction, I might try moving up a tire size to see if the change in gearing helped with launches, but that's probably the only reason I'd make the move, and that only after all the other necessary traction goodies and trick.
-1991 Integra, lots of goodies in an otherwise stock looking motorp; ITR front brakes.
-Xenocron programmable ecu w/datalogging port, LM-1 wideband, and Moates Ostrich are tuning tools of choice.
RIP 2005 Red Yamaha R6
www.m24x.com - Rocket Motorsports: For more technical engine discussions...
Radar will bounce off of a ride that is shiny and you keep clean.
Please don't PM me with tech questions. Use the forums!
MikeBergy is offline   Reply With Quote
Old 06-22-2006, 03:28 PM   #27
Rep Power: 9 typej is off the scale
From what I understand, putting on larger tires, would be like putting on a final drive ratio that is lower than what is factory. In my case, I'm going from
185 60R 14 to a 215 40R 17. Just swapping the tires causes a drastic change in the final speed at the given rpm based on the calculator. In the lower gears, I was about 2 mph faster with the taller tires, which means false reading on the speedometer. But, in fith gear I would be around 7 mph faster. Remember that the 17's overall diameter is about a 1/2 inch all around equalling to a little over an inch taller than the 14.
In your case you've gained in acceleration, but lost in speed. Also, you would have to shift quicker because of your rpms rapping quicker. The deeper gears, or larger tires would equate to you being in gears longer, not having quick acceleration, but being able to go faster, and having traction. At the drag strip they go with larger tires for a greater contact patch area, which would equal traction, but it would also mean that the final drive would be slightly altered.
I'm not trying to build a quick car. I'm building a fast car. There's a difference.
typej is offline   Reply With Quote
Old 06-22-2006, 03:31 PM   #28
TTIWWOP
reckedracing's Avatar
Ride:  90 z6-t hatch, 94 Bagged S10, 91 Lifted Mazda
Rep Power: 411 reckedracing has a reputation beyond reputereckedracing has a reputation beyond repute
reckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond repute
I would STRONGLY recommend you get the car running and actually drive it before you go getting custom gears built...
first gen crx + 100+mph = fucking scary...
I'll blow a hole in your face then go inside and sleep like a baby.
reckedracing is offline   Reply With Quote
Old 06-22-2006, 05:21 PM   #29
Blah blah blah....
MikeBergy's Avatar
Well, you aren't going to win any real races with a setup that you are planning. Shifting takes much less time than you think if that's the reason you are doing this. If you are going to the salt flats, fine, you are doing a fine job building a fast bonneville racer. But for drag racing, especially with a honda engine, you want to be in your powerband, and in your case, vtec, for as long as possible. longer gears just drop you out of your powerband, out of vtec, and out of the race. But I won't let my narrow mindedness hold you back if you want to spend gobs of money on specially made parts just so you can lose drag races, road races, autox's, any other race you can think of beside saltflats runs. Good luck.
Old 06-23-2006, 09:04 AM   #30
Um, that kind of hurt there dog. For a moment, I was respecting your opinion. Obviously we have two different mind concepts. I am basically doing research on what may be out there before I spend the money.
Old 06-23-2006, 11:13 AM   #31
I wear stretchy pants
Taco15's Avatar
Ride:  chevy s-10
Rep Power: 217 Taco15 has a reputation beyond reputeTaco15 has a reputation beyond repute
Taco15 has a reputation beyond reputeTaco15 has a reputation beyond reputeTaco15 has a reputation beyond reputeTaco15 has a reputation beyond reputeTaco15 has a reputation beyond repute
myspace
yeah but he has a point. Again thats what makes a honda special. when a v8 falls flat on its face in the top end. were just getting winded up. I think you should just find the shortest tranny possible,put a good lsd in and roll with it. if you drive on the highway then go install an Ls 5th gear. put some 18's if you want to lenghten the final drive some more and call it a day..lol.
however dont let us discourage you. its just something we never thought of before because we dont really need it. however. if you do ahead with this the go for it. Wish you the best of luck keep us informed of what you find. or if you change your mind
Its fashion man. The chicks you see walking down the runway dont wear practical clothes, they were something that was designed to make a statement. THat statement in turns influences and shapes other peoples designs and ideas.
Same thing with cars. Except with no attractive women... and a lot more gayness.
Taco15 is offline   Reply With Quote
Old 06-23-2006, 12:12 PM   #32
TTIWWOP
it appears to me that your mind concept = f'in video games...
what are you trying to do here?
Old 06-23-2006, 02:55 PM   #33
Blah blah blah....
MikeBergy's Avatar
I'm just trying to save you lot's of headaches and money down the road. There are plenty of people in the turbo honda b-series world that have had the thoughts you do. You think that you have thought of something original in the honda world? It's all been done. The cheapest and easiest way to find out if you like long gears, and if it will work for you, is to go out, buy an LS transmission and some huge tires for your turbo setup, and see how you like it. Lots of turbo people have had this setup in the past, thinking that longer gearing would be good, so they wouldn't have to change gears so often. 99% of them switched over to a shorter geared transmission. Just search on here, on honda-tech, on g2ic.com, etc... for people who have tried this combination. If you don't want to believe me, as I have a long geared LS transmission, and you don't want to believe the countless others who thought of this before you (probably after playing the same video game, lol), then do yourself a favor and buy an LS transmission, some big ol' tires, and try it for yourself. Like I said before, good luck.
Old 06-23-2006, 03:03 PM   #34
TTIWWOP
i would also highly recommend reading the honda tuning articles on the salt flat runs, the 3 and 5 mile courses
i know there were at least 2 honda tuning magazines that had salt flat cars on the front covers...
i think one was a JRSC B16, and the other was a NA B20vtec
i believe they were able to achieve their goal of a 200+ mph run on their second trip there, but it required an insane amount of money and work, and you need a 5 mile straight to get the car up to that speed...
good luck though
and just so you know, i think a stock GSR car reach 130 or 140 with no change in gears..
Old 06-23-2006, 04:37 PM   #35
Blah blah blah....
MikeBergy's Avatar
135 in my LS, with plenty of rpm left, just no power.
Old 06-23-2006, 04:42 PM   #36
TTIWWOP
i think thats the aerodynamic threshold they mention in honda tuning...
the motor just doesn't have enough power to overcome the aerodynamic friction at that speed...
Old 06-23-2006, 05:30 PM   #37
Blah blah blah....
MikeBergy's Avatar
aerodynamic drag, not to mention rolling resistance, and drivetrain drag. It's different for every car though, as different cars have different parasitic drag coefficients, not to mention more power available.
Old 06-23-2006, 08:26 PM   #38
Taco15's Avatar
Ride:  chevy s-10
myspace
back tot he topic Honda nerds! lol i think he gets our point Mike.
FS Type-R Final Drive Gear Set 4.78 jcarp613 Parts: For Sale/Trade/Wanted 0 01-24-2006 09:37 AM
FS Type-R Final Drive Gear Set 4.78 jcarp613 Parts: For Sale/Trade/Wanted 0 12-18-2005 11:38 PM
Opinions on 4.785 final drive install. Should I? CRAZYEG9 General Tech and Maintenance 2 04-28-2005 12:27 PM
JDM Integra Type-R 4.7 Final Drive QUICKEK4 Engine Building 0 01-22-2005 09:18 PM
