88 CRX Si Wiring Question
Old 12-21-2003, 03:40 AM   #1
Rep Power: 13 spdr is off the scale
I had posted a topic about this a few weeks ago but am yet to figure it out, it has to do with the fact that my CRX has no round plug to connect to the round plug that comes off of the small gray resistor box that comes out of the b18a1 engine wiring harness on the drivers side, the square plug is there, but the large round one that is supposed to come off of the cabin harness is missing, I was wondering if this problem has ever been encountered before, or why it is like this. The last engine that was in it was a ZC. Thanks...
spdr is offline   Reply With Quote
Old 12-21-2003, 04:46 PM   #2
Rep Power: 16 zc_hatch is off the scale
Send a message via Yahoo to zc_hatch
your crx was probably dpfi, and they converted it, and when they did, they probably soldered the injector box to the injectors instead of wiring the plug in there.
zc_hatch is offline   Reply With Quote
Old 12-21-2003, 04:58 PM   #3
Rep Power: 0 StumpedLSswapper is off the scale
if you are doin a ls swap you will need the vacumm sensors off the firewall of the ls that is the only thing i know of that it could be.... i have the same swap had a zc but blew it so know its time for a b18a1 ls motor had to use the vacumm pods from the integra
StumpedLSswapper is offline   Reply With Quote
Old 12-21-2003, 05:10 PM   #4
What do the vacuum pods look like? I just wish I could figure out why the round plug that is supposed to come out of the firewall of the car isnt there.. its just weird..
Old 12-21-2003, 05:12 PM   #5
I just read what zc hatch said, and to clarify more the box is hooked to nothing right now we're still in the process of wiring the engine up... thats why I'm wondering what to do there, maybe it is a dpfi but it shouldnt be because it is an Si?
Old 12-21-2003, 06:05 PM   #6
if its an si, it should of had a plug at the end of the injector resistor box. It may not match up to an ls, but you probably have to change one of the plugs to match, or eliminate the plugs and wire them all strait and solder them.
Old 12-21-2003, 09:26 PM   #7
well its an Si but theres no plug at all or wires.
Old 12-22-2003, 01:08 AM   #8
bump
Old 12-22-2003, 07:52 PM   #9
I guess I should just get a new cabin harness then?
Old 12-23-2003, 01:21 AM   #10
no no, just take a pic of whats goin on there and post it, it will be alot easier to figure out.
Old 12-23-2003, 07:54 PM   #11
alright ill do that pics should be up by this time tomorrow...
Old 12-23-2003, 08:28 PM   #12
Alright i got a picture of the resistor box on the drivers side thats coming off of the engine, circled is the round plug that comes off the engine harness, thats where the problem lies. There is no round plug coming out of the cabin harness through the firewall, the other square plug next to the round plug (the non green one) does have a mate that comes off of the cabin harness. But the round one doesn't, thats where the problem lies....
Old 12-24-2003, 10:05 AM   #13
Rep Power: 13 Captinb16 is off the scale
I know this might be dumb but that plug looks like it plugs into the distributor or its the wrong end and you have the harness backwards. Can you take a picture of the plug up closer and the one that your trying to plug it into.
Captinb16 is offline   Reply With Quote
Old 12-24-2003, 01:03 PM   #14
yeah it does look like that but it just has the cut off end of the plug from the teg still stuck in it, i can take a better picture
Old 12-24-2003, 01:27 PM   #15
And there is no plug to plug the round one into, thats the problem
Old 12-25-2003, 06:44 PM   #16
bump check my piiiic please =)
distributor and wiring harness question mrnice1058 HYBRID -> EG-EK / DC 5 10-30-2009 12:57 PM
wiring harness question mrnice1058 HYBRID -> EG-EK / DC 4 07-02-2004 08:20 AM
DX to SI wiring question (call me a moron) Civic_Tacoma ECU's, Electronics, and Tuning 4 06-08-2004 06:32 AM
Wiring Question on B16A2 spooncivic01 HYBRID -> EG-EK / DC 2 09-29-2003 01:56 AM
92 Cx Wiring Question dansace HYBRID -> EG-EK / DC 19 01-13-2003 01:35 AM
