90-93 Integra B18C1 swap
Old 11-04-2003, 07:34 PM   #1
Rep Power: 13 THE TECH is off the scale
Send a message via AIM to THE TECH
After reading the swap info on this, I have a few questions to clarify:
1. The B18C1 will bolt in directly with no mount issues or replacing of half shafts, etc.?
2. The B18C1 comes with a hydraulic tranny. Why does the trans need to be switched to a cable type? Is there any other parts that will be needed to purchase along with the tranny itself?
3. VTEC wires I assume to be meant as the VTEC engine wire harness?
4. Looks like I also need the OBD0 distributor and injectors. Are those the stock ones on the car or are they off a different motor?
Thanks for the help!
THE TECH is offline   Reply With Quote
Old 11-04-2003, 07:41 PM   #2
Ride:  94 Integra GSR
Rep Power: 31 brc80 is an unknown quantity at this point
1. Yes the b18c will bolt right in.
2. You need to get a cable tranny.
3. Depends on the ecu you run.
4. If your going with a b18c i think you may need to convert your car to obd 1
Please anyone if im wrong correct me.
1994 Acura Integra GSR
Power:
AEM V2 Cold Air Intake
GReddy 4-2-1 Header
GReddy Evo 2 Exhaust
Suspension:
Tanabe Sustec Pro S-0C
brc80 is offline   Reply With Quote
Old 11-04-2003, 10:32 PM   #3
Thanks for the help so far. Unlike my Supra, there are soo many options with these cars.
Old 11-04-2003, 10:38 PM   #4
Also, what is a good LSD for this motor/tranny combo?
Old 11-05-2003, 11:25 AM   #5
Ride:  crx
Rep Power: 16 legutki is off the scale
You dont have to switch to obd1 just get obd 0 injectors and dist form a b16 and it will plug right in. And to make it easier just get a skunk2 IM so you dont have to worry about the IAB's and of course you would run a obd0 pr3 ECU. Down side is you have to use 2 o2 sensors or chip you ecu to run off 1
legutki is offline   Reply With Quote
Old 11-05-2003, 12:54 PM   #6
Rep Power: 17 mellowboy is off the scale
Send a message via AIM to mellowboy
And i do have a pr3 ecu for sale if you need it. Also u can still you use the hydro trans if you get the hasport conversion kit.
mellowboy is offline   Reply With Quote
Old 11-05-2003, 01:02 PM   #7
GNU/Linux Evangelist
lsvtec's Avatar
Ride:  The Cheapest Road Bicycle I could get
Rep Power: 69 lsvtec is on a distinguished road
If this is a 92-93 Integra all of the OBD1 electronics on the B18C1 (the distro, the Injectors, etc) will plug right in, the ECU will work as well. You will have to add wires for VTEC and a knock sensor. You will still have to get a cable tranny or get the hydro conversion from HA Sport.
v3sw7+9Chw6ln3pr7Ock4ma9w3TXm3l7GDF i7Ce6+8t4MNb8Oen6g6RAOa26s5MRp6 hackerkey.com
lsvtec is offline   Reply With Quote
Old 11-05-2003, 04:26 PM   #8
And what if it's a 90-91??
Old 11-05-2003, 04:27 PM   #9
lsvtec's Avatar
Then you will have to get OBD0 injectors, an OBD0 VTEC distributor, and an OBD0 VTEC ECU.
Old 11-05-2003, 06:21 PM   #10
Ditto
Old 11-05-2003, 08:53 PM   #11
Are these the same as those that are stock with the 90-91 Integras?
Old 11-06-2003, 02:52 PM   #12
lsvtec's Avatar
The injectors are the same, the distributor and the ECU are not.
Old 11-06-2003, 07:11 PM   #13
What car/motor are the distributor and ECU from?
Old 11-06-2003, 07:38 PM   #14
lsvtec's Avatar
Unfortunately it has to be from JDM land. Any Civic that had a B16 or the 90-91 Integra (I think the XSi had the B16). You can use your stock injectors.
Old 11-07-2003, 01:50 PM   #15
Are these items generally hard to come by? If so, why is this motor the best choice for a swap?
Old 11-07-2003, 04:01 PM   #16
lsvtec's Avatar
I am not sure if they are hard to come by or not I have never looked. Try our classifieds. You can also try ebay, thepartstrader.com and various other Honda forums. I bet you can find what you need for reasonable prices with a little looking.
Old 11-07-2003, 04:07 PM   #17
Blah blah blah....
MikeBergy's Avatar
Rep Power: 49 MikeBergy is on a distinguished road
Send a message via AIM to MikeBergy
The obd0 distributor from a 90-91 teg will work, since the internals are all the same. you just need to hack one of mounting tabs off so it wont hit the vtec sole..at least I think its the vtec solenoid, I'm not looking at my head right now.
-1991 Integra, lots of goodies in an otherwise stock looking motorp; ITR front brakes.
-Xenocron programmable ecu w/datalogging port, LM-1 wideband, and Moates Ostrich are tuning tools of choice.
RIP 2005 Red Yamaha R6
www.m24x.com - Rocket Motorsports: For more technical engine discussions...
Radar will bounce off of a ride that is shiny and you keep clean.
Please don't PM me with tech questions. Use the forums!
MikeBergy is offline   Reply With Quote
Old 11-07-2003, 04:15 PM   #18
lsvtec's Avatar
Don't do this. Not only do you have to hack one of the mounting legs off, only one of the bolts lines up and you have to retard that distro almost all the way to get your timing right. Do it the right way with a VTEC distributor.
Old 11-07-2003, 04:18 PM   #19
Thanks for all the help so far!
Old 11-07-2003, 04:28 PM   #20
Blah blah blah....
MikeBergy's Avatar
Angry
Sorry for any bunk info, I was just giving info I've received from my honda technician friend. It's something you can do if you don't have like, what 150$ for a new pr3 dist? I think that's what they're going for. If anyone's got one let me know, and I'll buy it off of them, for a reasonable price. I'm doin a b16a swap into my 91 teg, and will be needing one eventually.out
Old 11-07-2003, 05:48 PM   #21
lsvtec's Avatar
It's no problem. The same suggestion was made to me when I built my LSVTEC. It's worth the $150 for the distro to do it right.
Old 12-21-2003, 03:40 PM   #22
It looks like now I'm gonna have to do an automatic for this swap. It has to be driveable by the wife who does not want to learn a manual tranny. Are there any differences in the swap with the auto?? Any suggestions as to beefing up the auto trans??
'89 Integra swap help 89integra HYBRID -> EG-EK / DC 14 01-16-2009 09:51 PM
92 civic hatch with integra LS swap / lambo doors troyer4k Vehicles: For Sale/Trade/Wanted 21 11-01-2004 05:06 PM
1st gen Integra Swap Overview (da) pissedoffsol Swap Articles 0 01-12-2004 02:15 AM
1st Gen CRX FAQ's pissedoffsol Swap Articles 0 01-12-2004 01:51 AM
b18c1 swap into dx crx pk23 HYBRID -> ED-EF / DA 1 09-10-2003 11:41 AM
