90-93 integra w/B16 which shift linkage?
Old 11-28-2003, 12:37 PM   #1
Rep Power: 15 assman is off the scale
i read the article and it said any shift linkage should work because the integra xsi came with a b16 so it should be same length bah bah bah, i had a LS tranny in my car and swapped it out for a b16 tranny, and now the shift linkage wont reach far enough/ go in right, i connected it, but the shifter stays too much towards the center stereo console, and 5th/Reverse wont go into gear , the shifter is so outta place dat 1st n 2nd gear hit my stereo and it moves side to side when in gera as if it was in neutral.. which shift linkage would be the best one to use for this?
assman is offline   Reply With Quote
Old 11-28-2003, 12:53 PM   #2
The LS links should be ok. If not I am sorry measure and make em work.
90 Integra Sedan
B20V 225 / 153
Old 11-28-2003, 05:19 PM   #3
Rep Power: 16 cointelpro is off the scale
how much u want for ur ls tranny? ^^ but im not sure about linkage, just go get the same linkage as the tranny. if its a b16 tarnny get a b16 linkage.
<span style=\'color:gray\'>I get paid to read e-mail, and click links.</span>
<a href=\'http://www.MikesPaid4Email.com/pages/index.php?refid=cointelpro\' target=\'_blank\'>SO CAN YOU!</a>
cointelpro is offline   Reply With Quote
Old 11-28-2003, 07:16 PM   #4
i got the 90-93 teg linkage, fit nice and all gears go in , but its stiff as hell i havtah really force it out of gear n stuff, i greased the bearings n stuf but iono, maybe i tightened the screw that goes inside through the linkage and shifter too tight?
LS tranny has a grind in 2nd gear at high rpms but if u still want it shoot me an offer ill let it go for dirt cheap its taking up space
Old 11-28-2003, 07:35 PM   #5
PM sent.
Old 11-28-2003, 09:17 PM   #6
Rep Power: 17 DA69 is off the scale
are you sure its not the tranny that is the problem? what mounts did you use. i think if all else fails maybe get the adjustable linkage for the swaps of b series into ef chassis.
Confusous say....It feels great to take off pants and jacket
DA69 is offline   Reply With Quote
Old 11-29-2003, 12:27 AM   #7
Slo86GT's Avatar
Rep Power: 48 Slo86GT is an unknown quantity at this point
Send a message via AIM to Slo86GT Send a message via MSN to Slo86GT Send a message via Yahoo to Slo86GT
Stock linkage. If you put in another shifter, like a short shifter or stocker, then you probably pinched the bracket to the pivot end on the shifter. There's usually some bearings built into the shifter and steel sleeves you're supposed to use on the bolt to keep that from happening.
- Jody -
2004 Colorado ZQ8 - I5, M5, Regular cab - 209.9whp/210.7wtq
1986 Mustang GT - V8, M5 - 213.0whp/279.2wtq
Slo86GT is offline   Reply With Quote
Old 11-29-2003, 01:27 PM   #8
you arent going to be happy with this swap the B16 doesnt have enough Torque to pull around this Hoss of a car. In any event I hope you like though. Should've went LSVTEC.
90 Integra Sedan
B20V 225 / 153
Old 12-02-2003, 07:14 PM   #9
Rep Power: 13 Travis is off the scale
Did you get your shifter turned around. Because I swaped a b16 and tranny in my 93 teg and my shift linkage fit perfect. At first I had the shifter (the acutal part you hold, turned backwords) and my 1,3,5 were all up in my sterio and 2,4,R whould not go into gear so I disconnect the shifter and spun in around and works great.
hope I could help
Travis is offline   Reply With Quote
Old 12-02-2003, 07:55 PM   #10
Rep Power: 30 StarBellieAngel is off the scale
Send a message via ICQ to StarBellieAngel Send a message via AIM to StarBellieAngel Send a message via MSN to StarBellieAngel Send a message via Yahoo to StarBellieAngel
first of all... this was his choice. maybe some people don't want to do an LS/Vtec setup. Second, if it couldn't haul it around, why would they put them in the Japanese Integras?? maybe it's not being put together to 'race' per se. He asked a question, he wanted an answer. not your opinion.
<span style=\"font-family:Tahoma\"><span style=\"font-size:10pt;line-height:100%\"><span style=\"color:black\">..::Bl<span style=\"color:red\">a</span><span style=\"color:black\">ck Wi</span><span style=\"color:red\">d</span><span style=\"color:black\">ow g</span><span style=\"color:red\">2</span><span style=\"color:black\">::..</span>
<span style=\"color:gray\">swapped~&amp;~ dropped
90 integra LS ~ B16A</span></span></span></span>
<span style=\"color:gray\"><span style=\"font-size:10pt;line-height:100%\">··¤(`×[¤<span style=\"color:red\"><span style=\"font-family:Tahoma\">if you don't like oral sex, shut your mouth!<span style=\"color:gray\">¤]×´)¤··</span></span></span></span></span>
StarBellieAngel is offline   Reply With Quote
Old 12-02-2003, 08:09 PM   #11
you go girl!!!!!
Old 12-02-2003, 09:05 PM   #12
Rep Power: 15 theB16tegguy is off the scale
180hp, 113lbs of trq. ... more than enough to make an ass out of you and your stock 04 silverado.
theB16tegguy is offline   Reply With Quote
Another Shift Linkage Help Needed Removal Thread! Hybrid93Hatch HYBRID -> EG-EK / DC 9 11-09-2009 06:39 PM
90-93 integra shift linkage qtmac_mien HYBRID -> EG-EK / DC 0 04-21-2004 02:37 PM
H22A in a 3rd gen (DB/DC) Integra pissedoffsol Swap Articles 0 01-12-2004 02:17 AM
1st Gen CRX FAQ's pissedoffsol Swap Articles 0 01-12-2004 01:51 AM
