90 civic b16a engine swap
Old 02-22-2007, 12:42 AM   #1
Rep Power: 0 mailey is on a distinguished road
Default 90 civic b16a engine swap
I have just put in a B16a ef9 jdm motor and tranny into my 90 civic si this is my first swap and didn't really struggle except now with the wiring got the vtec oil pressure and solenoid wired along with secondary o2 and knock to the ecm that came with engine
please tell me if this is correctvtec oil pressure B5, vtec solenoid A8, knock sensor B19 and sec o2 C8
now the problem for me is I got the complete harness with the engine and on the drivers side the harness that gets connected at the strut tower has 4 rows of wires a 3 4 4 3 round plug but the vechile harness only has 8 pin round connector. I found all my injector wires at this locatio(yellow,light blue, brown,red) as so my knock sensor and both vtec wires I guess what I am asking is can anyone help with taking the harness that came with the engine 14pin and wire it correctly to the 8pin that is on the vechile because other than the injector wire colors nothing else matches up
thanks in advance
mailey is offline   Reply With Quote
Old 02-22-2007, 11:17 AM   #2
Boosted ls/vtec ohh yeah!
boostin4fun's Avatar
Ride:  EM1 EBP boosted ls/vtec, EM1 EBP Daily Driver
Rep Power: 18 boostin4fun has a spectacular aura aboutboostin4fun has a spectacular aura about
I could be wrong but the jdm harness are left hand drive so they wouldnt work in the first place.
boostin4fun is offline   Reply With Quote
Old 02-22-2007, 11:18 AM   #3
Use the harness that was on the old engine and add the wires you need. You have the extra harness in case you need to chop off some plugs are what not so that is kind of handy.
Old 02-22-2007, 11:29 AM   #4
Ride:  02 chevy full size 81rx7 90crxhf
Rep Power: 6 90rexineffect is on a distinguished road
myspace
alrighty dont h8te cause im a newbie but im curious what will swap from a honda hatch to my crx body wise also how difficult it would be to put a crx si motor in my hf
90rexineffect is offline   Reply With Quote
Old 02-23-2007, 03:48 PM   #5
thanks used original harness problem solved ran four other wires all good
Old 02-23-2007, 03:49 PM   #6
thanks for the info did as you said used old harness and ran other wires all good
Old 02-23-2007, 03:52 PM   #7
Glad that I could be of some help!!
My build threads:
http://hondaswap.com/engine-building...c-build-84953/
http://hondaswap.com/engine-building...inished-92905/
I offer ecu socketing/chipping, tuning, swaps, and builds. PM me for details and pricing.
gsr whp 94_gs-r Engine Building 100 01-15-2007 10:00 AM
zc swap into 85 crx? devnjeff HYBRID -> ED-EF / DA 4 07-10-2005 11:09 PM
1st Gen CRX FAQ's pissedoffsol Swap Articles 0 01-12-2004 01:51 AM
Need some help with Trim Names YangpaNemsay General Tech and Maintenance 7 08-31-2003 04:43 PM
All This Reference Material, And No Cel Code Chart Slo86GT Members' Lounge 5 06-13-2003 10:31 AM
