90 CRX-B18A1 Swap... Half Shaft Problem
Old 11-30-2008, 11:28 AM   #1
Rep Power: 6 SoDakCRX is on a distinguished road
Default 90 CRX-B18A1 Swap... Half Shaft Problem
First a little background info:
I got a 90 CRX given to me: bare shell, stripped, poor body work, wiring hacked, and just generally a mess.
I purchased a 91 Integra LS wrecked in the rear with a b18a1. only problem was that it was an auto. wanting to convert to manual, i purchased a trans on ebay, long story short had a hole in the case. had a shop weld it up and had a transmission guy go through the tranny, everything looked good.
I am attempting to use the fronts suspension/axles/brakes etc. off of the integra. I read that you have to use a halfshaft that matches the transmission. not thinking the ebay listing for my trans could be incorrect, I purchased a b18 M/T half shaft. i say this because i was told when trying to use a b16 halfshaft with a b18 transmission there are some lining up issues.
While putting in the transmission, we had a difficult time getting the left side motor mount to line up. but finally after some adjusting, got everything to bolt up.
I just finished cleaning up and painting all the Teg suspension, and got it all installed.
went to install the half shaft, and it slides in without a problem, but where the plate on the end goes to bolt up, nothing lines up. in fact i cant even get the bracket to sit flush against the engine.
since then i have purchased 2 more half shafts to make sure it wasnt a b16/b18 issue, (one b16 and one b18) and neither of them work either
any help or ideas?
SoDakCRX is offline   Reply With Quote
Old 11-30-2008, 12:41 PM   #2
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
Rep Power: 214 INJEN78 has a reputation beyond repute
INJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond repute
the halfshaft is bent,ive never seen the holes be off like that,they are always just to the left a little,never up or down like that
R.I.P BEN LEE2/24/08 we love and miss you
http://burnoutbox.activeboard.com/in...BID=127652&p=1
GOOD FAST CHEAP,
you can pick only two.
fast and cheap isn't good
good and cheap isn't fast
good and fast isn't cheap
INJEN78 is online now   Reply With Quote
Old 11-30-2008, 12:49 PM   #3
3 bent halfshafts? what are the odds?
Old 11-30-2008, 02:08 PM   #4
sunofabitch
its a b17 transmission..... now i need a b17 half shaft from a 92 gsr
Old 11-30-2008, 02:23 PM   #5
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
sunofabitch
o my bad,i didnt read that you tried more than that,,
GOOD FAST CHEAP,
Old 11-30-2008, 05:47 PM   #6
Ride:  91 ef B18 swap w/AC!
Rep Power: 5 red91efhatch is on a distinguished road
B17? good luck....
red91efhatch is offline   Reply With Quote
Old 11-30-2008, 07:31 PM   #7
i got it figured out and fixed...
thanks guys
Old 11-30-2008, 07:41 PM   #8
Ride:  i have 14 cars i drive my sohc turbo ef
Rep Power: 34 97hatch is a jewel in the rough97hatch is a jewel in the rough97hatch is a jewel in the rough
what was the problem
SOME PEOPLE ARE LIKE SLINKIES. NOT REALLY GOOD FOR ANYTHING BUT THEY BRING A SMILE TO YOUR FACE WHEN PUSHED DOWN THE STAIRS.
97hatch is offline   Reply With Quote
Old 11-30-2008, 07:43 PM   #9
Green on the scene.
MthaFuknGreen's Avatar
Ride:  Fuckin Prelude Si 2.1l 1990
Rep Power: 70 MthaFuknGreen has a brilliant future
Send a message via AIM to MthaFuknGreen myspace
he thought it was a b18, but it was a b17.
MthaFuknGreen is offline   Reply With Quote
Old 11-30-2008, 10:32 PM   #10
sunofabitch
Old 12-01-2008, 07:20 PM   #11
are you two serious it dosent matter if its b16 b17 b18 b20 they are all the same some have female outer joint and some have male outer joints but they all bolt up the same
Old 12-01-2008, 08:25 PM   #12
first of all, all i know is what ive read, i am not a honda expert, nor do i pretend to be one.
the reading that i have done has said that the I shaft has to match the transmission.
when i looked up my transmission code, the only stamp i could find on the transmission was YSK1. when i looked that up online.... one site said it could be from a 92 gsr with lsd.
after i read this i assumed that being a b17 transmission was the problem. fed up with the intermediate shaft dilemma, i modified one of the 3 shaft i had. i had to grind down the bracket so that #1 it would clear the block to finish its rotation to sit flat against the engine where it bolts up. #2 so that where the bolts went in it was flush and not at a goofy angle.
this pic represents where i had to "trim" the bracket to make it fit. the darker the red color, the more i had to take off.
since then i have done some more reading just for my own knowledge and have come to realize a few things:
#1 YSK1 was stamped onto all cable transmission housings, so im still not sure what kind of transmission i have
#2 I'm not convinced that if you have a b18 trans you have to have a b18 shaft and the same for the b18 shaft. as near as i can tell they are identical except a 3 digit code on one of the sides. otherwise, the dimensions are nearly identical
i'm not sure why none of the shafts i had didn't work
Tags
b18, b18a1, crx, ef to da, engine, swap
Civic Integra B Series Intermediate Shaft Half Shaft RSS-Bot Auctions 0 02-26-2008 10:43 PM
integra gsr half shaft intermediate shaft b18c1 b16a2 RSS-Bot Auctions 0 11-25-2007 08:13 PM
Intermediate shaft integra civic gsr - axle half shaft RSS-Bot Auctions 0 11-18-2007 11:13 PM
B18 B16 intermediate shaft, half shaft RSS-Bot Auctions 0 11-11-2007 10:43 PM
Half shaft seal problem & Car pulls to right BMike HYBRID -> ED-EF / DA 0 09-17-2005 03:01 PM
