91 auto to manual swap
Old 11-10-2004, 11:18 AM   #1
Rep Power: 12 steve92civic is off the scale
I got the car for 100 dollars and I want to keep it daily driveable. A b16 sounds like a good start. Is it hard to swap it over to manual? thanks
steve92civic is offline   Reply With Quote
Old 11-10-2004, 11:26 AM   #2
Rep Power: 20 b204dr is an unknown quantity at this point
Send a message via AIM to b204dr
with general knowledge no its not . go to a junk yard and yank out a clutch system , buy the swap , or get it all buying a clip up to you but always some thing not working
friction created heat which creates power=does this apply in the word of automotive
b204dr is offline   Reply With Quote
Old 11-10-2004, 11:33 AM   #3
I forgot to mention that I was planning on getting the complete swap from the hmotorsonline including the hasport mounts . Would this include just about everything that I need, besides the clutch pedal and assembly and the cables?
Old 11-10-2004, 11:53 AM   #4
should include nearly every thing but will always need to buys hoses , find botls and etc off course , hows the things under the hood of the car currently, while engines out perfect time to replace what needs to be replaces to , break booster , master cylinders , break lines etc since ur going from auto to manual those mounts still might need mofication i know on my 00 the mounts needed minimal changes for the auto to manual i trims some stock ones , and used the 00 b16 rear but on a 91 dont know
Old 11-10-2004, 01:24 PM   #5
What car, what year? Ive done 2 manual swaps... 1 - CRX and my Integra...
90 Integra Sedan
B20V 225 / 153
Old 11-10-2004, 02:55 PM   #6
SlushboxTeggy's Avatar
Ride:  1997 Integra
Rep Power: 196 SlushboxTeggy has a reputation beyond repute
SlushboxTeggy has a reputation beyond reputeSlushboxTeggy has a reputation beyond reputeSlushboxTeggy has a reputation beyond reputeSlushboxTeggy has a reputation beyond reputeSlushboxTeggy has a reputation beyond repute
Send a message via AIM to SlushboxTeggy Send a message via MSN to SlushboxTeggy
about how much did the integra cost because im like an addict without his fix with this auto. i fucking hate it.
Like water on a duck's back, just let it roll off...
RIP Shaunie T. O'Reilly- 1986-2006
SlushboxTeggy is offline   Reply With Quote
Old 11-10-2004, 03:25 PM   #7
I got everything for $200... but you need to look to spend about $500-$600 in parts.
You will need:
Pedals - $50
Clutch Cable and all bracketry - Buy new Cable $45
Trans - $200+ (can be from any 90-93 Integra as long as it's cable)
Clutch Kit - $100+
Flywheel - Stock will work $25+
Soldering Iron & solder.
90 Integra Sedan
B20V 225 / 153
Old 11-10-2004, 05:34 PM   #8
the car is a 91 4 door sedan. sexy and sleeper
