91' B16A1 swap running crappy!!!
Old 02-12-2004, 02:24 AM   #1
B18C1THatch is off the scale
Me and my friend just swapped out his old D16A6 out of his 91' Civic and put in a B16A in and then he took it to the shop and had it wired for VTEC and it starts and runs now but the ECU's throwing 2 codes #'s 8. and 9. (8) is the Top Dead Center sensor and (9) is the CYP cylinder sensor. Does anyone know how to replace these and where they are??? Just out of curiosity what about is a 91 hatchback with a stock b16 soposed to run in the quarter mile?
Thanks!!
B18C1THatch is offline   Reply With Quote
Old 02-12-2004, 02:32 AM   #2
I'll be back...
B16RacerN2NR's Avatar
Ride:  96 DB8, 06 Mazda 5
B16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond repute
B16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond repute
Send a message via AIM to B16RacerN2NR myspace
Thanks!!
those codes are in the distributor...usually motors don't come with very good distributors...you could have the b16 dizzy rebuilt using 90-91 ls dizzy internals...or run a 91 Si and cut of the bottom right wing so it fits just until you can get a new b16 one or your old one rebuilt. as for 1/4 mile times, depends on the motor, i've seen some stock b16's in a crx make a low 14 second passes and other b16 crx's make mid 15 second passes. of course it has to do with driver, tires, track conditions, ect. but you get what i mean.
Mercedes-Benz STARt program, here I come...
B16RacerN2NR is online now   Reply With Quote
Old 02-12-2004, 02:19 PM   #3
Thanks man!!! It just pissed me off bad because I have a 87' Lude Si beater with the A20A3 with intake and apexi muffler and it smokes the B16 it trys i can tell cuz it goes crazy in first gear when the VTEC kicks in.
Old 02-17-2004, 12:00 AM   #4
brian11to1 is just really nicebrian11to1 is just really nicebrian11to1 is just really nicebrian11to1 is just really nice
I dotn thinkg you can use the d Distributor... but more than likely you can use the same OBD B series distributor. Good Luck... you should also be throwing a code 15 as well....
Old 02-17-2004, 12:04 AM   #5
Iquark is off the scale
Send a message via MSN to Iquark
You're probably out of luck on that dizzy if it's bad, the best option would be to go to Hmotorsonline and get a new one for 150$. Sorry, but dizzys are expensive...
Ian
Iquark is offline   Reply With Quote
Old 02-17-2004, 12:23 AM   #6
Ian
they are not new they are used from japan... get the shit str8 y0'
Complete B16a1 Engine Swap Parts List iluvmyCRX HYBRID -> EG-EK / DC 8 03-10-2010 05:45 PM
B16a1 Swap int3gl2a_typ3l2 HYBRID -> ED-EF / DA 21 06-11-2003 01:59 AM
B16a1 Motor Swap Into 91' Integra robthievez HYBRID -> EG-EK / DC 7 02-16-2003 09:33 PM
B16a1 Swap dickman_jason1 HYBRID -> EG-EK / DC 5 01-14-2003 12:02 PM
B16a1 Crx Hf Swap Wiring Nightmare pleasehelpimlost ECU's, Electronics, and Tuning 9 01-07-2003 09:49 PM
