91 crx d16a6 Idle at 2500 rpm
Old 09-24-2009, 03:50 PM   #1
Rep Power: 1 crxnonvtec is on a distinguished road
Default 91 crx d16a6 Idle at 2500 rpm
its a 91 crx dx with a d16a6 swap, jackson racing supercharger, str cam gear, exhaust....I changed the iacv 3 difftimes all the same result, coolant temp sensor is good, swapped map two times same result, iat tested good, new distributor from cap to shaft, new main relay, new o2....vacuum tested good so did the fuel pressure...it runs great just stays at 2500 it dropped once when I drove it a lil and never did again. and no the throttle cable isnt stuck. also I had swapped the whole intake assembly back to the stock intake with all the components and still at 2500rpm. anyone got suggestions?? NO CODES!!!!
crxnonvtec is offline   Reply With Quote
Old 09-24-2009, 03:56 PM   #2
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
Rep Power: 214 INJEN78 has a reputation beyond repute
INJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond repute
fitv??? maybe redo the timing?
R.I.P BEN LEE2/24/08 we love and miss you
http://burnoutbox.activeboard.com/in...BID=127652&p=1
GOOD FAST CHEAP,
you can pick only two.
fast and cheap isn't good
good and cheap isn't fast
good and fast isn't cheap
Old 09-24-2009, 05:45 PM   #3
timing is dead on and I dont have an fitv...I have something like it on the back of the manifold but I swapped that out too and did nothing
Old 09-24-2009, 06:57 PM   #4
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
hmmm are all the intake bolts tight?
GOOD FAST CHEAP,
Old 09-24-2009, 07:09 PM   #5
now its a 91
Ride:  91 civic dx hb with si harness and jdm d15b
Rep Power: 6 89hatchd15b is on a distinguished road
Send a message via AIM to 89hatchd15b
sounds like a vacuum leak. check all the hoses and intake manifold gasket and such.
89hatchd15b is offline   Reply With Quote
Old 09-24-2009, 08:12 PM   #6
if it was a vacuum leak then y did the vacuum test good on the gauge? all the hoses are new and routed properly
Old 09-24-2009, 08:36 PM   #7
now its a 91
I had the same problem on my jdm d15b vtec and it was a leak at the intake manifold gasket. Does that engine have an idle control diaphragm next to the throttle?
Old 09-26-2009, 10:16 AM   #8
yes it has the diaphram but its sucking back and not touching the throttle the throttle blade is completely closed ...and all the vacuum lines are new and ran properly theyve been gone over multiple times...and the intake gasket is new and tightened properly
Old 09-26-2009, 11:39 AM   #9
now its a 91
I don't know, I have only seen vacuum or timing issues causing a high idle. I will have to think about this one and get back to you.
Old 09-26-2009, 02:29 PM   #10
dont feel bad it seems no one can help me with this problem
Old 09-28-2009, 08:44 PM   #11
yes.... ive gone through so much
Old 10-01-2009, 12:52 PM   #12
Ride:  90 crx w/zc dohc
Rep Power: 8 Fernpatch has a spectacular aura aboutFernpatch has a spectacular aura aboutFernpatch has a spectacular aura about
myspace
This may sounds stupid but have you played with the idle air screw on the throttle body at all? that may be out of adjustment. Also have you made double sure that there are no air pockets in the cooling system? The IACVs that you have been using were they new or used? did you try and take any of them apart and see if they came unscrewed inside?
What I write is my own opinion based on what I have done. Your own results may vary...
"Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall, torque is how far you take the wall with you." --Anonymous
Fernpatch is offline   Reply With Quote
Old 10-01-2009, 06:24 PM   #13
Rep Power: 14 78civic will become famous soon enough
Loose nut behind the wheel? Just kidding.
Try pulling the neg off the battery to see if something needs to be cleared electronically..?
I'd first think it's vacume related. Try some carb cleaner squirted around the charger/intake. If it boggs, you know it's in that area.
Lastly, call Jackson and ax them if this is a regular occurance?
Keep us posted.
E
"If you can read, thank a teacher"
"If you can read it in English, thank a VET"
78civic is offline   Reply With Quote
Old 10-01-2009, 09:45 PM   #14
it did the same thing with the stock intake on also...and this has been on going for months now the battery is disconnected for days at a time sometimes.
Old 10-01-2009, 09:48 PM   #15
i would doubt three iacv's ...two off running cars would malfunction the same...and ive had the car up to temp with fan running and bled the coolant system no air was in it....still stumped and going nuts
Old 10-01-2009, 09:59 PM   #16
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
hmm...thats wierd..who did the harness?
GOOD FAST CHEAP,
Old 10-01-2009, 11:01 PM   #17
you get the BRAKE
LS_VTEC's Avatar
Ride:  99 YZF-R6
Rep Power: 43 LS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to behold
What ECU are you using?
eg hatch (jdm b16) sold
1999 Yamaha YZF R6 (modded)
http://hondaswap.com/engine-building...ow-pics-102486 sold
LS_VTEC is offline   Reply With Quote
Old 10-01-2009, 11:06 PM   #18
you get the BRAKE
LS_VTEC's Avatar
Ride:  99 YZF-R6
does your engine have a fast idle control solenoid valve? The 91 crx with the 1.6L engine has one....
Old 10-01-2009, 11:19 PM   #19
i have 3 ecus 1 chipped from jet and 2 stock it does the same with all. no fitv it has something similar but u cant tighten anything on it like the obd1 models that was obviously one of the first things to pop up when i searched idle problems
Old 10-02-2009, 12:16 AM   #20
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
yea the d16a6 mani doesnt have that plate..
GOOD FAST CHEAP,
Old 10-02-2009, 12:45 PM   #21
D-Series Ninja
riceracerex's Avatar
Ride:  90' Honda CRX Si
Rep Power: 11 riceracerex is a jewel in the roughriceracerex is a jewel in the roughriceracerex is a jewel in the roughriceracerex is a jewel in the rough
myspace
when my chip was not connected all the way on my pm6 ecu it caused it to idle @ 2500 but I was not able to rev past 3500 and it ran horrible. So it does not sound like there is a problem there.
have you tried a compression test? IAC Valve or TPS Sensor?
My D16z6 in My 93' Civic had this problem but after it warmed up sometimes it would stop the erratic idle, so just putting those out there.
"¿ʞɐǝɹɟ ɐ ǝɹ,noʎ uǝɥʍ 'ʇı ʇ,usı 'ʎlǝuol s,ʇı" uɐɯ ǝlqısıʌuı uɐ ɟo sɹıoɯǝɯ ɯoɹɟ ǝʇonb ɐ ɟo pǝpuıɯǝɹ ɯ,ı
riceracerex is offline   Reply With Quote
Old 10-02-2009, 12:57 PM   #22
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
lol read the thread man..he already tried all that..
GOOD FAST CHEAP,
Old 10-04-2009, 10:48 PM   #23
im going nuts ...i just keep staring at the engine in the garage waiting for it to say TADAAAAAA Im fixed its my last option hahahaha
Old 10-05-2009, 01:08 AM   #24
I'll be back...
B16RacerN2NR's Avatar
Ride:  06 Mazda 5, 91 Civic DX
Rep Power: 156 B16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond repute
B16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond repute
Send a message via AIM to B16RacerN2NR myspace
Well of course the vacuum test read good. You're not 'losing' vacuum and your engine is running fine. Spray some throttle body cleaner around all points of the intake manifold gasket. If you the idle changes, you know where your problem is.
It's not idling high for no reason so don't just quit and think you've covered all angles...
Real Eyes Realize Real Lies
B16RacerN2NR is offline   Reply With Quote
Old 10-07-2009, 12:12 PM   #25
im not quitting but after almost two years and being on every forum and reading through the shop manual u cant blame me for losing some hope hahahaha...and I sprayed starting fluid around the intake and no rpm change....I just dont know what would make the idle shoot up to 2500 and stay there...it runs good just idles high...no sputtering or hesitation ... sometime it sucks air through the hole in the tb and sometimes it doesnt idk ive just been over the engine so many times...and its always harder to describe something on the internet
Idle high w/AC off and idle is fine w/AC on thewraith HYBRID -> BA-BB /CA-CD 8 09-11-2009 12:12 PM
Chevrolet : Silverado 2500 2500 2003 Chevrolet Silverado Duramax T- Diesel NO RESERVE RSS-Bot Auctions 0 03-14-2008 08:53 PM
b16a idle problem not iacv or fast idle toqeer1986 HYBRID -> EG-EK / DC 9 12-12-2007 03:06 PM
Having idle problems, idle keeps surging 91civicsiracer General Tech and Maintenance 17 10-04-2004 08:40 AM
High Idle Than Bam Irratic Idle Accordturbo94 General Tech and Maintenance 39 11-08-2003 12:22 AM
