#27 |
Greenhorn
Ride: 1990 DA9350 Integra
Hi,
Painfil thing to get to the end of but don't give in, a suggestion for rectification of this fault could be the FITV - Fast Idle Thermo Valve. I recently had an issue with my B18A1 and after replacing TB and IACV I had less money and the same fault. This component is located under the throttle body, three 10mm bolts hold it to the inlet manifold. Remove it then on the fitv you will see there are 2 x 8mm bolts/screws that hold a cover plate on, remove them and under this plate there is a valve that is white in colour and it will be loose, tighten it all the way home reassemble the fitv and refit it and presto!!! no more high idle. FITV - Fast Idle Thermo Valve |
#29 | |
SOHC on this!!
Head could be cracked and letting in air. Unlikely though.
#31 |
Ride: 90 crx w/zc dohc
If you are going to part it out let me know what you have and where you are. I think you may have allot of the pieces that I have been trying to find for my brothers 89 hatch project. Please pm me with what you are parting out and how much you want for it.
What I write is my own opinion based on what I have done. Your own results may vary... "Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall, torque is how far you take the wall with you." --Anonymous |
| Idle high w/AC off and idle is fine w/AC on | thewraith | HYBRID -> BA-BB /CA-CD | 8 | 09-11-2009 12:12 PM |
| Chevrolet : Silverado 2500 2500 2003 Chevrolet Silverado Duramax T- Diesel NO RESERVE | RSS-Bot | Auctions | 0 | 03-14-2008 08:53 PM |
| b16a idle problem not iacv or fast idle | toqeer1986 | HYBRID -> EG-EK / DC | 9 | 12-12-2007 03:06 PM |
| Having idle problems, idle keeps surging | 91civicsiracer | General Tech and Maintenance | 17 | 10-04-2004 08:40 AM |
| High Idle Than Bam Irratic Idle | Accordturbo94 | General Tech and Maintenance | 39 | 11-08-2003 12:22 AM |
