91 Crx Si Swap
Old 09-19-2004, 02:27 PM   #1
TrueStifmeister is off the scale
Send a message via ICQ to TrueStifmeister Send a message via AIM to TrueStifmeister
Thumbs up
I got a 96 civic ex motor from my friend and I was wondering what I should do ECU wise. Can I use the 96 ex ecu, can I make it obd1, or must I use an obd0 ecu? Send help please
TrueStifmeister is offline   Reply With Quote
Old 09-19-2004, 04:18 PM   #2
CRseX84 is off the scale
Send a message via AIM to CRseX84 Send a message via MSN to CRseX84 Send a message via Yahoo to CRseX84
if u wana do it its gona be tricky.. u g2 get a conversion for the OBD0-OBDII. and it could just be alota crap man. id sell the motor and then buy a b18a .. that will give u more hp and more tq... good luck man
CRseX84 is offline   Reply With Quote
Old 09-19-2004, 04:38 PM   #3
n8dawg is off the scale
The only real solution is to seel the motor and save up for a jdm b16a, I have one swapped in my rex and it feels so damnnnnnnnn good. Plus there are tons more parts that you get for it. If you really want to go all out, keep your 91 as a daily driver and go find a piece of shit 89 crx hf for a few hundred and do the swap in it since it is about 2-3 hundred pounds lighter than your Si. Good Luck
n8dawg is offline   Reply With Quote
