Greenhorn
Ride: 91 Integra GS
hey guys i have a 91 teg with an OBD0 b16 that is sputtering. not misfireing cuz it idles smooth. i cant figure out why. i have changed my grounds, plugs, wires, cap, rotor, coil, igniter, and triple checked timing and it is dead on. someone please help!!! im about sick and tired of this car and about to burn it!!!!
wwtdd?
if you just changed the cap and rotor, check the timing.
Warning: If you are reading this then this warning is for you. Every word you read of this useless fine print is another second off your life. Don't you have other things to do? Is your life so empty that you honestly can't think of a better way to spend these moments? Get out of your apartment. Meet a member of the opposite sex. Stop the excessive shopping and masturbation. Quit your job. Start a fight. Prove you're alive. If you don't claim your humanity you will become a statistic. |
Ride: 91 civic hatch w/b16 and 91 civic hatch project car
are you running both o2 sensors, Im having a similar problem with my obd0 b16, it sputters i only had 1 o2 sensor hooked up, had a code 2, hooked up the second 02 sensor and it got worst. I have one in the header and one in my test pipe. I believe the sensors need to be in the upper part of the headers. Let me know how yours is set up
Ride: 90 civic ex 4 dr B16
he should only need one o2 sensor hence obd0 check the ecu for flashing codes and if not try a different ecu. u can also change your fuel filter maybe spark plugs? just going through some of the shit thats not listed that you checked above.
1993 Chevy Corsica...R.I.P 1990 Plymouth Acclaim...R.I.P 1991 Ford Mustang 4cyl...SOLD 1993 Buick Regal ...SOLD 1993 Taurus S.H.O...R.I.P 1986 Olds Cutlass...R.I.P 1991 Integra ls special...R.I.P 1997 Integra ls auto...R.I.P 1989 Integra ls...R.I.P 1988 Ford Thunderbird 5.0...SOLD 1993 240Sx ...SOLD 1995 Civic D15b7 mini me w/ z6 head ......R.I.P 1994 Civic EX Coupe ... In middle of 5 speed swap..R.I.P 1988 Civic Dx d16y7... SOLD 1990 Civic Ex B16 "with a single intake cam"<~~~CURRENT |
#5 | |
Ride: 1990 ED DX jdm D15B dual carb;x 1991 ED DX B16A OBD0
91 Styling Civic, they should both be in the header. One reads the exhaust from two cylinders and the other reads the other two. Last edited by Korax; 09-05-2009 at 12:08 PM. |
#6 |
thanks thats what i thought, I need to get the bungs welded in so i can get it running properly or do you know where i can find a header that is set up for the 2 02 sensors
| 91 teg sputtering! cant figure out why! need help!!! | 91integraXSI | Integra | 0 | 08-26-2009 02:04 PM |
| sputtering B16 | hatukazi | HYBRID -> ED-EF / DA | 22 | 03-10-2008 06:29 AM |
| b18b1 Sputtering | jOnZ | General Tech and Maintenance | 5 | 02-06-2008 10:34 AM |
| Sputtering when in boost! | gettocrx | Forced Induction | 20 | 01-20-2007 06:30 PM |
| Abit of sputtering during low-mid. | dominik | HYBRID -> ED-EF / DA | 0 | 02-25-2006 03:14 PM |
