92-95 Axle in an EF
Old 02-07-2005, 02:02 PM   #1
Rep Power: 16 90vtec is off the scale
I have a friend that has a set of 92-95 Dx axles and wants to swap some parts. Can these go into my 90 hatch? I need new one because I'mm going to LSD but I'm not sure if they'll work in my car?
"The only replacement for displacement is technology!!!!!"
90 Civic DX
Coilovers with Adj Struts
HMT 14b Turbo
Audi FMIC
DOHC 2.25 full exhaust
Short Shift DIY Tuned ECU
90vtec is offline   Reply With Quote
Old 02-07-2005, 02:13 PM   #2
thistownsucks...
hybrid89's Avatar
Rep Power: 33 hybrid89 will become famous soon enough
Send a message via AIM to hybrid89
not sure, but chances are the splines are different, so my guess would be NO! maybe someone else knows for sure
id rather have a hondata and a stock block
then a sleeved, pistons/rods combo and a hack or fmu
hybrid89 is offline   Reply With Quote
Old 02-07-2005, 02:21 PM   #3
Originally posted by hybrid89+Feb 7 2005, 02:13 PM--><div class='quotetop'>QUOTE(hybrid89 @ Feb 7 2005, 02:13 PM)</div><div class='quotemain'><!--QuoteBegin-90vtec@Feb 7 2005, 02:02 PM
I have a friend that has a set of 92-95 Dx axles and wants to swap some parts.* Can these go into my 90 hatch?* I need new one because I'mm going to LSD but I'm not sure if they'll work in my car?
[/b][/quote]
I have the inner portion from my old DX, so if the spline is diff, it still have the spider bearing right? If the outer portion is different he also has extra ef out knuckle, but it's sounding like i'm gonna be shit out of luck and he get no intercooler.
&quot;The only replacement for displacement is technology!!!!!&quot;
90 Civic DX
HMT 14b Turbo
Audi FMIC
Old 02-07-2005, 06:35 PM   #4
Ride:  06 Chevy Silverado
Rep Power: 83 Jeef has much to be proud ofJeef has much to be proud ofJeef has much to be proud ofJeef has much to be proud ofJeef has much to be proud ofJeef has much to be proud ofJeef has much to be proud of
Send a message via AIM to Jeef
Check the lengths
Ex 89 crx si,91 & 95 Civic owner.
06 Silverado RCSB 20's, 2/4" Belltech lowering kit, waiting for 2 more cylinders, 1.9 more liters, and 208 more hp engine swap.
Jeef is offline   Reply With Quote
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
