93 integra int. shaft work with 95 gsr trans?
Old 11-03-2008, 05:07 AM   #1
scottie fizzle
HATCHET_HONDA's Avatar
Ride:  90 civic si hatch, 91civic dx hatch
Rep Power: 17 HATCHET_HONDA has a spectacular aura aboutHATCHET_HONDA has a spectacular aura aboutHATCHET_HONDA has a spectacular aura about
Send a message via AIM to HATCHET_HONDA myspace
Default 93 integra int. shaft work with 95 gsr trans?
soo i came upon an intermediate shaft for the b16 swap in my ef. its from a 93 teg. but i have a hydro trans from a 95 gsr. it seems to fit and it bolts up fine. is this a workable axle combo? or do i need the 95 shaft.....
admit it..your a ricer....
90 si hatch jdm d15b swap(done)
91 dx hatch b16 swap (in progress)
b16a block
95 gsr p&p head
skunk 2 valvetrain
stage 1 cams
type r bottom end
tri y header
stage 3 act clutch ftw
HATCHET_HONDA is offline   Reply With Quote
Old 11-03-2008, 02:16 PM   #2
D16SiHatch's Avatar
Rep Power: 33 D16SiHatch has much to be proud ofD16SiHatch has much to be proud ofD16SiHatch has much to be proud ofD16SiHatch has much to be proud ofD16SiHatch has much to be proud ofD16SiHatch has much to be proud ofD16SiHatch has much to be proud of
yep. just be sure to get da axles to match the int. shaft
91 Civic Si
b18b1, I/H/E, 6000k HID kit, 94 teg cluster
Parting mustang out to buy another civic
D16SiHatch is offline   Reply With Quote
Old 11-03-2008, 02:25 PM   #3
scottie fizzle
cool...i was hopin it didnt have diff splines or somethin
b16a block
95 gsr p&p head
skunk 2 valvetrain
stage 1 cams
type r bottom end
tri y header
Old 11-03-2008, 02:43 PM   #4
D16SiHatch's Avatar
no sure doesn't, you're good to go. and the da axles fit perfectly in the Si hubs, as i imagine you may already be aware of.
91 Civic Si
Old 11-04-2008, 04:17 AM   #5
scottie fizzle
lol yea that part i knew about but when i was installing the trans and such it hit me that it was from a 95 not a 93 like all the other teg parts....i was kinda like uh oh...them axles can get a lil tricky sometimes
b16a block
95 gsr p&p head
skunk 2 valvetrain
stage 1 cams
type r bottom end
tri y header
Tags
95gsr, axles, b16a, ef91, halfshaft, swap
Will D trans vss work in LS trans? scuzz HYBRID -> EG-EK / DC 6 10-26-2008 11:56 AM
Civic Integra B Series Intermediate Shaft Half Shaft RSS-Bot Auctions 0 02-26-2008 10:43 PM
integra gsr half shaft intermediate shaft b18c1 b16a2 RSS-Bot Auctions 0 11-25-2007 08:13 PM
Intermediate shaft integra civic gsr - axle half shaft RSS-Bot Auctions 0 11-18-2007 11:13 PM
will the intermediate shaft work in a b16 crx? wickedplastikman HYBRID -> ED-EF / DA 3 12-14-2003 02:22 PM
