95 teg b18b into 91 hatch base
Old 07-09-2003, 07:31 PM   #1
Rep Power: 13 swapdohc is off the scale
I have a 91 civic hatch with a d15 and a 4sp manual, I also have my fiances' tanked 91 teg with a b18b and hydro tranny (And anything else I can use). I know that I need mounts to fit the motor, do I need anything else? So far this is what I have thought of:
1-Will the pedal assemby/clutch master cylender bolt in w/out major surgery?
2-Will the frot hub assembly with the brakes fit?
3-If so, should I use 95 teg axles?
4-Should I use the existing (Civic base) wire harness on the b-18 or should I transplant the entire teg harness into the civic?
I know I'm asking for alot of info but any help would be apeciated, The teg fell in my lap and would like to do something different, if I can make this work cleanly I intend to put a vortec supercharger on it shortly after the swap has been completed. Thanks.
<span style=\'font-family:Times\'><span style=\'font-size:14pt;line-height:100%\'><span style=\'color:red\'>&quot;It's not what you can buy, It's what you can build!&quot;</span></span></span>
swapdohc is offline   Reply With Quote
B18B into a 95 hatch CX 95hatchcx HYBRID -> EG-EK / DC 2 12-31-2003 02:09 AM
Anyone here? 2000Si Members' Lounge 14 12-09-2003 11:55 AM
Complicated B18B in 89 DX Hatch, I have questions. H22AEG2 HYBRID -> ED-EF / DA 1 07-02-2003 01:44 AM
B18b Into 6th Gen Civic Hatch aznhottiekj HYBRID -> EG-EK / DC 0 06-01-2003 02:04 AM
Building A B18b 92 Civic Hatch TSMCartman Forced Induction 6 02-16-2003 01:05 PM
