Almost did it.
Old 07-29-2004, 02:49 AM   #1
oldschoolcivic is off the scale
Ok I turned over the b16 after the swap and nothing. I got spark and fuel is flowing throught the fuel rail. No codes on the ecu. It sputtered like it was going to run for about a second or two, but that was it. Any suggestions?
oldschoolcivic is offline   Reply With Quote
Old 07-30-2004, 03:22 AM   #2
I3ackfire is off the scale
Ya it has to be the timing, I had this same problem about a month ago
I3ackfire is offline   Reply With Quote
Old 07-31-2004, 12:34 AM   #3
b18typeR is off the scale
does it run for like 2 or 3 secs then cut off??? make sure u dont have any of the wiring mixed up, or any of the sensors i was having this problem when doing a head swap and it was the 2 sensors on the throttle body.
b18typeR is offline   Reply With Quote
