This needs to be moved. You r car isnt even a EF OR DA. You have an EG 92-95 Civic. So post in the correct forum
Things you'll need: Clutch Clutch pedals assembly clutch reservoir master cylinder clutch hard lines from donor car shift linkages shifter bushing shift knob and boot 5 speed ecu tranmission manny tranny mount... __________________
90 Integra Sedan B20V 225 / 153 I DO NOT answer tech questions via PM. Use the forums!!! |
TTIWWOP
Ride: 90 z6-t hatch, 94 Bagged S10, 91 Lifted Mazda
i believe a 93 is hydro, if not then sue me...
but if it is hydro then you need clutch pedal assembly, hydro lines, manual trans, flywheel, clutch and pressure plate... and possibly axles, not sure on the auto intermediate shaft hydro lines includes the slave cylinder, and the clutch assembly includes the master cylinder by the fire wall you will need to unplug your auto computer, but you have to splice the wires that keep you from starting the car unless its in neutral or park, and you should be set... EDIT: shifter setup and manual tranny mount ^^^^^__________________
I'll blow a hole in your face then go inside and sleep like a baby. |
yes recekd you are correct, but ill be sueing you anyhow. 92+ HONDA = hydro, 94+ ACURA = hydro. I forgot toe mention flywheel, clutch kit
#5 |
TTIWWOP
lol, between our two replies he'll know everything he needs
lol __________________
#7 |
This topic has been closed
![]() Why? It is in the wrong place. Please post your topic in the right forums. Hybrid is not for suspension or interior posts. EG is not for EF questions, and so forth. If you have any questions, please PM the moderator who closed this topic. -The moderating Team |
| auto to manual conversion | cheese9988 | General Tech and Maintenance | 14 | 06-04-2004 08:10 PM |
| Manual to auto conversion? | kaishaku | General Tech and Maintenance | 3 | 04-01-2004 11:28 AM |
| 93 Coupe Disc Conversion & Auto to Manual Conv. | j177oney | General Tech and Maintenance | 4 | 03-30-2004 08:39 PM |
| Auto to manual conversion | steeze | HYBRID -> EG-EK / DC | 7 | 12-16-2003 12:56 AM |
| Auto To Manual Conversion | lostdesigns | HYBRID -> EG-EK / DC | 13 | 03-17-2003 12:00 PM |
