auto to manual swap wiring???
Old 01-18-2004, 03:27 PM   #1
Rep Power: 15 thegreat1310 is off the scale
Send a message via AIM to thegreat1310
Angry
im doing a auto to manual swap in 90 civic what do i do with all the wires in the center consol theres like a lot of them,thanks for any help need it asap
thegreat1310 is offline   Reply With Quote
Old 01-18-2004, 10:11 PM   #2
Rep Power: 13 894DSiR is off the scale
should be 2 big wires black with white stripe (i think), they are for park/neutral safty switch, you can run them to the clutch switch on your new manuel pedals or just connect the 2 together. thats what i did, 88's didnt have clutch switch (at least didnt show it on my 88 helms), do that so you can start your car, then if you want reverse lights there is a yellow wire and a green with black strip wire next to it (again im not sure about colors on yours) but you will need to run them to the reverse switch on your new trans. the rest of the wires you can just leave. i have done the swap on a few ef's its not that hard
894DSiR is offline   Reply With Quote
Old 01-19-2004, 06:29 PM   #3
thanks that worked like it should
auto swap question asmallsol HYBRID -> EG-EK / DC 3 11-18-2003 10:03 PM
Civic Auto To Manual Swap sutscivic HYBRID -> EG-EK / DC 1 03-31-2003 01:57 AM
Need Advice For Auto To Manual Swap onetyme_sam HYBRID -> EG-EK / DC 2 03-28-2003 02:09 AM
Engine Swap - Auto To Manual Tranny? luVTEC HYBRID -> EG-EK / DC 1 03-11-2003 08:33 AM
Auto To Manual Swap civicdude98 Engine Building 4 03-06-2003 01:51 PM
