auto to manuel-DA
Old 06-02-2008, 08:45 PM   #1
Rep Power: 0 b16integra is on a distinguished road
Default auto to manuel-DA,engine codes
my car was converted to manuel awhile back not by me and i cant seem to get the motor level. any suggestion?
also i have a code 20,9 i know the 20 is eld but my car dont haveone so im lost it does have a pr3 ecu and its ls/vtec
b16integra is offline   Reply With Quote
Old 06-02-2008, 09:47 PM   #2
Brutal Moderator
BrutalB83's Avatar
Ride:  97 Integra LS Coupe
myspace
You took out your automatic transmissions and replaced it with a Latino?
PSN Network ID: BrutalB83
Old 06-05-2008, 10:10 PM   #3
you know what i mean ..smartass
Old 06-05-2008, 11:03 PM   #4
Brutal Moderator
BrutalB83's Avatar
myspace
Hmmm...the positioning of the motor might have to do with how they handled the mounts. If they did a quick hack and weld rather then measuring carefully or using an after-market mount that might be the problem...
For the ECU codes, not sure exactly. What year are the head and block?
Old 06-05-2008, 11:29 PM   #5
Ride:  06 Chevy Silverado
Rep Power: 88 Jeef has much to be proud ofJeef has much to be proud ofJeef has much to be proud ofJeef has much to be proud ofJeef has much to be proud ofJeef has much to be proud ofJeef has much to be proud ofJeef has much to be proud of
Send a message via AIM to Jeef
manual = you shift your gears
manuel = a sweaty mexican guy
Ex 89 crx si,91 & 95 Civic owner.
06 Silverado RCSB 20's, 2/4" Belltech lowering kit, waiting for 2 more cylinders, 1.9 more liters, and 208 more hp engine swap.
Jeef is offline   Reply With Quote
87 manuel to Auto swap Snyiper Civic and CRX - EW 6 03-02-2008 10:45 PM
auto to manuel ?? dok HYBRID -> EG-EK / DC 6 01-16-2008 09:41 PM
automatic ecu swap to manuel ecu tougi3 ECU's, Electronics, and Tuning 4 12-17-2007 03:41 AM
will a manuel P28 work on an auto car? CRVTEC EG ECU's, Electronics, and Tuning 15 01-18-2005 07:56 PM
Accord From Auto To Manuel haccord141 General Tech and Maintenance 3 04-05-2003 01:29 AM
