Autometer Sport Comp 5" tach Surging above 5k rpms
Old 12-10-2003, 10:56 PM   #1
LSTurboCivic4DR is off the scale
Hey I have a 89 Civic LX with a 2000 b18b and it is all running off a 90 integra LS PR4 ECU and wire harness. I was having troubles with the factory tach surging above 5k rps, like it would just bounce up real fast! So i figered fuck it, I would just install a nice sport comp 5 inch unit and that would take care of it, well i hooked it up to my MSD box, and I am still having the same problem, it sux because when it surges into the higher RPM's, it causes the shift light to come on and i am only at like 5500! If anyone has any ideas let me know, Thanks, Frank.
LSTurboCivic4DR is offline   Reply With Quote
Old 12-11-2003, 07:43 AM   #2
RETIRED
pissedoffsol's Avatar
Ride:  Electric Scooter
pissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to behold
first theing to do is check that its hooked up right.
next is to check the source- the dizzy.
Old 12-11-2003, 10:13 PM   #3
I have double checked everything in hhokup, it is very easy, power, ground, illumination, and the tach signal wire goes to my MSD box tach output signal, it work fine in normal conditions. I think that this dizzy that you speak off is what it is. Can you please tell me what you mean by the dizzy?!?!?!? I do not know what this is! I think that if it a source for tach singnal it may be it because as I stated the problem is happening on my factory tach in the gauge cluster also. Thanks alot for your help man! Frank.
Old 12-11-2003, 10:35 PM   #4
Slammed89Integra's Avatar
Ride:  2007 Scion TC, 2005 Suzuki GSX-R 600
Slammed89Integra has a reputation beyond reputeSlammed89Integra has a reputation beyond repute
Send a message via AIM to Slammed89Integra myspace
Dizzy=Distributor.
Slammed89Integra is offline   Reply With Quote
Old 12-12-2003, 11:16 AM   #5
thistownsucks...
hybrid89's Avatar
hybrid89 will become famous soon enough
Send a message via AIM to hybrid89
Take the cap off of your distributor. The two main wires that attach to the coil tend to come loose. If you have a bad connection at all, high rpm's will show fluxuation in the tach reading. I went through this problem before. Also make sure that your rotor is solid. Alot of them break loose from the metal insert that clamps to the dizzy shaft. Start there. Almost positive it is one or the other or both.
hybrid89 is offline   Reply With Quote
Autometer Tach adnoh Car Audio / Security / Electronic Accessories 18 01-15-2010 10:41 PM
FS: 5" autometer tach jordan Parts: For Sale/Trade/Wanted 6 03-31-2004 11:41 PM
difference between turbo sizes SnailOnARampage Forced Induction 4 11-12-2002 03:53 PM
Stock tach vs Autometer Monster Thing paragus General Tech and Maintenance 7 10-16-2002 07:27 PM
