This is a discussion on B16 CRX hesitation in the HYBRID -> ED-EF / DA forum
Just put a B16a into my 91 si crx a week ago. The motor was sitting a while in Japan. I got it over here to through in my rex. The swap went easy. It runs good, no check engine light, idles smooth.
My problem ...
| | #1 |
| Just put a B16a into my 91 si crx a week ago. The motor was sitting a while in Japan. I got it over here to through in my rex. The swap went easy. It runs good, no check engine light, idles smooth. My problem is: When cruising at around 4 grand, it hesitates when accelerating until you hit v-tec. Its almost like a miss fire but not quite. I have already done plugs, wires, rotor, cap, coil, ran seafoam through it, and injector cleaner. I also swapped out the TPS sensor today but no difference. Any ideas? |
| | #2 |
| what cel is it throwing? could be knock sensor or map..... |
| | #3 |
| Its not throughing a cel. Swapped out the map and tps already. No change. |
| | #4 |
| the only thing that comes to my mind is timing. What's it set at? |
| | #5 |
| I haven't thoched the timing since it was pulled in Japan. I haven't even taking the dizzy off it. |
| | #6 |
| my car had similar symtoms but it turned out to be one of the O2 sensors. no light on the dash, but the red led was lit up. 1 flash. it cures my problem tho. |
| | #7 | |
| Quote:
| | #8 |
| I unpluged the one O2 sensor (white plug). It seems to have cleared up. I am going to replace it tomorrow. Will let you know how it runs. But as of now I believe that was the problem. I started with the green O2, but it was still there a bit. It has no check engine light even with the O2 unplugged. |
| | #9 |
| Cool. Please do let me know. If it's something that simple I'll be happy! |
| | #10 |
| | #11 |
| man, i've got the same problem too! except mine is all of the time it seems to miss at everything but WOT, but less noticable at low rpm's. and i get a cel on long deceleration in-gear for o2b after it's warm. i've replaced both o2 sensors, as well as my valve cover/spark tube seals/gaskets, and cleaned the plugs. whatever it is is causing one pair of cylinders(2&3) to lean out, and I don't know what it is. i've tried more things too, but yeah. i'm putting in new ngk wires today also. never know. they're jdm stock ones from the import. let us know what it was to fix it, and i'll try that. i still have to replace the tps and check timing. but other than that, i'm probably gonna take the head off and check valves, etc.. so frustrating! i'd be interested to know what fixes your guys' problems. carl425, try making sure you have the two o2's not switched around. assuming you have the obd0 b16a. that'll cause that problem. ps. i'm not threadjacking. just ignore me. i'm here to observe. Last edited by freak86; 08-07-2007 at 12:50 PM. |
| | #12 |
| | #13 |
| Check your compression. For all you know that headgasket is going and it doesen't matter how many miles are on the motor. It matters how long the motor has been sitting around as well. |
| | #14 |
| lol. yeah. ditto. i just found out my headgaskets leaking into the manifold. and i'm putting money on it causing my o2 code and my drivability issues. so, yeah, like he said. look for leaks and check your compression. and make sure there's not coolant in your oil, and no oil in your coolant. |
| | #15 |
| It was the O2 sensor. |
| | #16 |
| that's good to hear |
Similar Threads | ||||
| 1986 Honda Accord LX-i w/ B16 swap MUST SEE!!! | racetek82 | Vehicles: For Sale/Trade/Wanted | 1 | 06-04-2012 08:06 AM |
| TONS of parts for sale B16, GSR, Type R | Envy_Motorsports | Parts: For Sale/Trade/Wanted | 28 | 02-08-2010 09:43 AM |
| FS: B16 head, B16 block, B16 tranny Cheap in good shape | Mr.slippyfist | Parts: For Sale/Trade/Wanted | 18 | 04-09-2009 06:48 PM |
| b16 head b20 block... wanna swap b16 internals??? | electric95122 | Engine Building | 4 | 12-19-2006 07:18 AM |
| All Swap Info for EF | Riceras | HYBRID -> ED-EF / DA | 2 | 02-07-2005 02:20 PM |
