B16 CRX throwing code 6
Old 01-13-2008, 11:56 PM   #1
Rep Power: 4 craftymatt is on a distinguished road
Default B16 CRX throwing code 6
Swapped a B16a into a 91 CRX HF; OBD0 PR3 ECU
Anyway, I'm getting code 6 from the ECU (Defective Coolant temp circuit/sensor), and I can't figure out why. The sensor is plugged in, I've tried swapping the sensor (and tested the resistance of both sensors, they were the same), and I traced the connector pins back to ECU/ground. The car runs okay but is obviously in limp mode (bad idle, 7200rpm rev limit, no VTEC etc).
If I use the old HF ECU (PM8) it does NOT throw the code and runs much better (indicating that it is reading the ECT correctly).
I've searched around to see if maybe on some of the PR3's the coolant temp sensor came in on a different pin, but that doesn't seem to be the case. Why else would this happen? Bad ECU? ECU code is 37820-PR3-003, is 003 some weird revision or something? I opened the ECU up and nothing appears to be damaged/modified.
craftymatt is offline   Reply With Quote
Old 01-14-2008, 03:37 AM   #2
you get the BRAKE
LS_VTEC's Avatar
Ride:  99 YZF-R6
Rep Power: 43 LS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to behold
Is the sensor bad? Did you test for resistance in the circuit itself? Is there sufficient coolant in the engine?
eg hatch (jdm b16) sold
1999 Yamaha YZF R6 (modded)
http://hondaswap.com/engine-building...ow-pics-102486 sold
LS_VTEC is offline   Reply With Quote
Old 01-14-2008, 01:42 PM   #3
CT'sFinest
CRX18703's Avatar
Ride:  1991 Honda CRX SI
Rep Power: 0 CRX18703 is on a distinguished road
Send a message via AIM to CRX18703 Send a message via Yahoo to CRX18703
Its probably a lose ground, i had the same problem with minds
CRX18703 is offline   Reply With Quote
Old 01-14-2008, 09:09 PM   #4
Banned
Ride:  1995 honda civic DX coupe
Rep Power: 0 riceburner89 is on a distinguished road
Send a message via AIM to riceburner89 myspace
Thermostat?
riceburner89 is offline   Reply With Quote
Old 01-14-2008, 11:40 PM   #5
you get the BRAKE
LS_VTEC's Avatar
Ride:  99 YZF-R6
Originally Posted by riceburner89 View Post
Thermostat?
The thermostat wouldn't cause a code-6, it just opens when the coolant reaches a specific temperature.
Old 01-17-2008, 05:04 PM   #6
figured it out!!!
Turns out on the HF there is a wire coming into the ECU (B9 on the ECU connector) that tells the ECU when the car is in reverse. Every time I went into reverse (which happened to be every time since I had to back out of the driveway when I wanted to drive it) it would apparently freak out the ECU and it would trigger a code 6. This also explains why the HF ECU didn't have a problem.
Anyway, I pulled B9 from the connector and now the car runs great. Finally I can hit VTEC!!!
b16 head b20 block... wanna swap b16 internals??? electric95122 Engine Building 4 12-19-2006 08:18 AM
91 throwing engine code 20???????????? 91gsinva Integra 8 10-07-2006 05:59 PM
All Swap Info for EF Riceras HYBRID -> ED-EF / DA 2 02-07-2005 03:20 PM
Code 43 O2 sensor what do I do? B16 CIVIC Gooseguir ECU's, Electronics, and Tuning 1 12-28-2003 10:51 PM
codes civichbwithb18a1 HYBRID -> ED-EF / DA 1 10-03-2003 03:24 PM
