B16 into 90 Integ
Old 02-19-2004, 02:47 AM   #1
Rep Power: 12 EFB18A1 is off the scale
hey guys i just wanted some info and advice on a b16 swap into a 90 integ. i was planning on getting the longblock and swapping it in. it was either that or a complete zc swap. but my question is what would i need if i swap in a b16 into the car? would all the original parts in the teg, like the dizzy, ecu and harness plug right into the b16? by the way its the 1st gen b16 not the SiR II ones. thanks for any helpful replys.
EFB18A1 is offline   Reply With Quote
Old 02-19-2004, 03:03 AM   #2
you have much to learn. First of all ditch the very thought of a ZC in an Gen. 2 Integra, the integra was graced with the B series for a reason.
To put the B16 in the integra you will need:
Engine & ECU. You will also need to modify the LS engine harness to run VTEC.
You need to freaking use the search feature on this site, and also go to reference section as well. It was made for no reason.
90 Integra Sedan
B20V 225 / 153
Old 02-19-2004, 03:13 AM   #3
sorry. not use to using the search feature i thought it wouldve been better to just post a thread so it'll be easier to find and get more opinion from the specific questions i need to ask. one more thing, so there is no way that i can mod the ecu to run the b16? would the dizzy on the ls work on the b16 and it is possible to run the b16 with the ls tranny right, since it is a b-series tranny after all. i do understand that it'll probably be slower since the ls dont have a close gear ratio like the b16.
Old 02-19-2004, 03:19 AM   #4
Rep Power: 17 Iquark is off the scale
Send a message via MSN to Iquark
Just get the long block and the ecu, and you'll be just fine. Then you have to run 4 wires I believe for vtec and the other stuff that goes with it, which won't be very hard with the pin-outs from hybridhonda. The LS tranny will bolt right up, and it's not as bad as everyone says, you'll still have a quick car, my friend has a G2 teg with the same setup, it's pretty quick. Good luck with your stuff,
Ian
2003 Infiniti G35
1992 Civic Si Hatch
JDM B18C, with a B16 head, and B16 Tranny on P30 ECU
Civic Type R Cams on stock valve train, uprgade to Skunk2 IM soon...
AEM SRI, Greddy 4-2-1 header, 5-Zigen Fireball Catback
H&R Race Drop, KYB AGX 4 way adjustable Shocks
00 GSR Wheels in Goodyear GS-D F1s
Skunk2 Upper Control Arms
EBP paint
1996 Civic CX Hatch - R.I.P Dec. 26, 2002
Iquark is offline   Reply With Quote
Old 02-19-2004, 03:20 AM   #5
Smonkeyboy's Avatar
Ride:  RPS-13
Rep Power: 48 Smonkeyboy is a jewel in the roughSmonkeyboy is a jewel in the roughSmonkeyboy is a jewel in the roughSmonkeyboy is a jewel in the rough
Send a message via AIM to Smonkeyboy Send a message via MSN to Smonkeyboy Send a message via Yahoo to Smonkeyboy myspace
yeah, the LS tranny works. and i dont think you can use your ECU, you know, since your B18 doesnt have Vtec at all, it would be kinda hard.
but you can get a PR3 for like $100-150
-Scott
(O=O/RPS 13\O=O)
....finally SR'd
http://www.nissanpacific.com --- for the nissans
http://www.myspace.com/SkylineScottro -- My MySpace account durrrr.
Smonkeyboy is offline   Reply With Quote
Old 02-19-2004, 03:27 AM   #6
thanks for the info guys. you guys were a big help. well i guess i'll try and get the b16 and the ecu. but how does the price 700 sound?
Old 02-19-2004, 03:52 AM   #7
for the longblock, pretty good. good luck, if i came across as an asshole, i'm sorry.
90 Integra Sedan
B20V 225 / 153
Old 02-19-2004, 03:59 AM   #8
wait 1 last question. so does the ls dizzy work on the b16 motor?
Old 02-19-2004, 04:37 AM   #9
yes must shave a leg off it though. or you can drop 150 for one from hmotorsonline.com
90 Integra Sedan
B20V 225 / 153
Old 02-19-2004, 02:11 PM   #10
Rep Power: 12 turboant is off the scale
www.g2ic.com everthing you need to now about 2gen teg's
turboant is offline   Reply With Quote
Old 02-19-2004, 02:19 PM   #11
Ride:  94 Integra GSR
Rep Power: 31 brc80 is an unknown quantity at this point
Im running my b16 off a chipped pr4, and using a vafc for fuel and vtec control. I found it to be a much better combo then using the pr3. The pr3 likes better gas then we have, and also looks for a knock sensor, and a second 02 sensor. Just my .02
1994 Acura Integra GSR
Power:
AEM V2 Cold Air Intake
GReddy 4-2-1 Header
GReddy Evo 2 Exhaust
Suspension:
Tanabe Sustec Pro S-0C
brc80 is offline   Reply With Quote
TONS of parts for sale B16, GSR, Type R Envy_Motorsports Parts: For Sale/Trade/Wanted 25 10-16-2008 01:08 AM
building a b16 jinstuh Engine Building 2 02-03-2004 11:03 PM
Hybrid jdm b16 tranny crxfreak HYBRID -> ED-EF / DA 2 06-30-2003 09:55 PM
B16 Head On An Old 1990 Integ Block numberonepimpsta HYBRID -> EG-EK / DC 6 06-22-2003 01:58 AM
B20/vtec Or Stay With My B16? Slimtadder HYBRID -> EG-EK / DC 9 02-09-2003 02:52 AM
