Well, I've been trying to figure this out for the past 4-5 months with no luck what so ever. I have an 88 CRX with a b16 SIR I. When I bought the car everything worked great and it performed like a champ. After about 6 months, problems began occuring.
Problem: I've been experiencing a huge loss in performance. These are my symptoms:
What i've tried so far:
Any suggestions would be greatly appreciated. This problem has frustrated me to the point where I just don't want to throw down more money replacing things unless I can isolate the problem. |
You say you replaced the O2 sensor. Are you aware you're supposed to have 2 O2 Sensors on a OBD0 B16?
One located on the 1-4 exhaust runner merge point, and one at 2-3's merge point. Completely disconnect the O2 sensor and see if it clears up a little. Running without an O2 connected is better than having them connected wrong. And as for your wiring being crappy. That can cause every problem known to Honda =) Fix it, or pay me to fix it. Rywire | V __________________
Owner of Rywire.com http://www.rywire.com ECU Jumpers, DPFI conversions, subharnesses etc... |
When you swapped in the b16, did you switch the wires for the O2 sensors? I had this same problem, but to a lesser extent, with my b16 in a 90 CRX.
The Japanese motor has the plugs on the O2 sensors backwards so you need to cut off your stock plug and wire that one to the ECU separately and then use the plug that came with your motor (for the second O2 that you didn't originally have) and wire that to where your original plug was. I hope this makes sense. If it doesn't fix it or makes it worse, its an easy to put back, something worth trying for sure. __________________
No tech questions through PM please! B16 CRX....you will be missed
update: she PM'd me, said he never had a secondary O2. That's probably his issue, however it does sound more severe than i've ever heard of.
#5 |
I disconnected the o2 sensor and the symptoms still exist. It actually seems worse than before. It still confuses me that this is the issue when everything was running smoothly and it has just gradually gotten worse and worse. Anyone have a pic where the 2nd o2 sensor should be located?
#6 |
You DEF need 2 O2 sensor inputs. The stock b16 has a 4-2-1 header and there is an O2 at each Y so each sensor reads 2 cylinders. If you're running an aftermarket 4-1 header you can wire the same O2 sensor to both inputs of the ECU for a ghetto fix that should make the car run better. Ideally however, you need to have the 2 O2 sensors in the correct place for the car to run right.
#8 |
If its 4-1 you're always going to have some problems. I've heard of people running 2 O2 sensors right next to eachother on the collector and of people making the sensors read only 1 tube each also. Neither of these is ideal and you should do some more research on how to setup your electronics.
#9 |
It's probably a 4-2-1, they're more common.
#10 |
um...wtf? Do you know him? How can you possibly make that assumption? I see way more 4-1 headers on cars because of the whole "4-1 increases overall hp" thing. I'll wait for a reply from the dude that owns the car.
#11 |
haha don't get all beligerent. talked on PM a lil. It's tre 4-1's increase performance but i see more people with CRX's worried about ground clearance buying the 4-2-1's. =)
Yes it's pure speculation, but I'll bet you $2.00 over paypal that it's a 4-2-1 LOL serious! haha __________________
#12 | ||
Ride: 1991 CRX Si
18 posts and already on some peoples nerves... lets here it for Rywire!
![]() Quote:
you are derogatory to people, then push them in your direction to pay you for your services? nice. ![]() __________________
1991 CRX Si 2007 Civic Si Sedan My Engine Swap Write-ups: HG FPR Wheel Smiley Cluster. Adapters. Last edited by Andrew; 10-27-2006 at 06:07 PM. |
#14 |
Well, it turned out to be a simple ignition problem. I replaced my cap/rotor/wires/plugs and the bogging went away. I am still having an issue where it will randomly bog while cruising, and I have to completely let up on the gas and push back down on the gas and it will then be fine. I'm wondering if my fuel pump is going out or has crap in it...
#16 |
Yeah I finally took it down and had it looked at. The problem with random bogging while cruising was caused by my o2 sensor being bad. With my custom dc header, the o2 sensor is farther down the exhaust and therefore doesn't get as much heat and fouls up quicker. A new heated o2 sensor was wired in to provide the heat instead of the 1 wire o2 sensor that I had previously. My bogging problem is now gone.
#17 |
How many o2 sensors do you have? If you only have 1, make sure it is wired correctly at the ecu. Have your cars always had the bogging problem? Or has it just started recently? If it was working correctly at one time, like mine was, your wiring is probably fine and you probably need to replace the o2 sensor.
#18 | |
#19 |
Most likely the o2's are causing it. Either it is bad wiring or the sensor(s) are on their way out. If the problem has been happening since the swap, make sure the wiring is correct. If you are pretty confident the wiring is correct, I'd replace the sensors and see if that solves it.
#20 | |
| TONS of parts for sale B16, GSR, Type R | Envy_Motorsports | Parts: For Sale/Trade/Wanted | 25 | 10-16-2008 01:08 AM |
| B16 obd0 wiring help | wardatron | ECU's, Electronics, and Tuning | 1 | 10-18-2006 12:36 AM |
| FS: Obd0 B16 Swap Complete EF Swap Mounts, linkage,ecu Cheap | Mr.slippyfist | Parts: For Sale/Trade/Wanted | 10 | 09-06-2006 09:20 PM |
| b16 obd0 to 0bd1 conversion - Injector question | awdriscol4 | HYBRID -> ED-EF / DA | 1 | 10-27-2004 04:56 PM |
