i need some help with the wiring.
if any of you have suggestions or shematics for me to follow that would be appreciated. I have searched and the information i am looking for is not in the search. my dizzy has more pins in it than my old one on the d15 does. whats the deal? can you guys help me out? thanks alot -Matt |
The B16a has 2 additional wires in the dizzy.
A green/white one and a green/yellow one. They are Cylinder position sensors. Both neccessary for mpfi. From a Dx harness you will end up with 2 unused wires, and you will have to add 9 wires. You will have to switch at least 2 wires on the ecu. Add 1. Knock sensor 2. Injector #2 3. Injector #4 4. 2nd o2 sensor(shielded) 5. Cyl. sensor (dist) 6. Cyl. sensor (dist) 7. Vtec solenoid 8. Vtec pressure sensor 9. Vtec pressure to ground swap your TPS wires add a resistor box extend your temp sensor wire to reach other side of motor. If this hasn't confused you, try these links. http://www.deepstaged.net/dxtosir.htm http://www.4thgenerationcivic.com/how-to&#..._conversion.htm Unless you are willing to sit down and spend some time learning what wires are what and why, you would be better off buying a conversion harness. It really is alot of fun to build your own harness. If you got questions after you read for the next couple days, I'll try and help. See photo album #950 for finished example of Sir wiring. Ralph |
is that it for the wiring? because it looks much more difficult thna that sounds. i will try and start that tonight. what car do i get an injector resistor off of? i can't find any mpfi civic/crx's here but there is alot of the integras with the d16a1(zc replica) and alot of b20a5 preludes. thank you very much. this is my first swap and im doing it all myself -Matt |
#8 |
ok. i have wired most of it up now there is something i am stuck on.
there is some sort of electrical sensor on the back of my transmission and it looks to be in the same spot as my speedo cable was on my d15 ![]() that is a pic of the back of my trans and thats the sensor i can't figure |
#12 |
Ride: i have 14 cars i drive my sohc turbo ef
ok i think but im not sure that you can remove the vss and put the sendending unit in that plugs into your spedo cable. also you havea hydo trans in a cable car so you will have to get a cable to hydro kit or convert to a hydro clutch hope i have helped.
SOME PEOPLE ARE LIKE SLINKIES. NOT REALLY GOOD FOR ANYTHING BUT THEY BRING A SMILE TO YOUR FACE WHEN PUSHED DOWN THE STAIRS. |
#13 |
Save yourself the trouble and gte a cable transmission from a 90-93 Integra. Or any B16 (88-91 S1, J1, Y1 or JDM YS1 <--- Has LSD)
90 Integra Sedan B20V 225 / 153 I DO NOT answer tech questions via PM. Use the forums!!! |
#14 |
that is a cable tranny, i know it looks hydrolic from the OBD 1 plug, but some B-series cable trannys come like that, theres a 10 mil bolt holding that in, just swap it out with the one from your old 4 speed tranny, then you can plug in your speedo cable.
#15 |
ok... cool i will get right on that. i was going to say yeah it is cable i meade sure of that when the boys dropped it off at my house.
when i get home i will swap the speedo sendor or whatever it is lol thanks again -Matt |
#16 |
well thanks guys for all your help
my engine is now running i just have to find out something for a shift linkage... the local shop wants $400 for a hasport shift linkage...(cdn) so once i fig that out i will be running thanks for the wiring help, i had every wire right -Matt |
#17 |
$400 holy poop, screw the hasport linkage get the SIR linkage from steve at hmotorsonline, he charges $75.
#18 |
hmmm... i could....
what would happen if i cut off the stabilizer and bolted it to the body of the car? i was told it was ok because i have enjo(racing) mounts and it wouldn't change gear when i accelerate because the mounts were too stiff and the engine wouldn't move enuf to shift... i think the stabilzer movs the whole thing so it doesn't shift when the engine moves... if i have the right idea good... will it work of should i do something else? -Matt |
#19 | |
#20 |
Ride: 1989 Honda CRX HF
Good job getting that shit to run. Buy shift linkage. At most, pay $160 off ebay for AZrace linkage.
They say that you only live life once, but if you live like me....once is enough! -Frank Sinatra |
#21 |
i have the shift linkage working... the reson i thought it would shift gears is that the stabilizer would be bolted to the undercarriuage and it wouldn'ty move with the engine like stock... the only prob with this is that when i floor it the shifter moves a little bit... which isn't that bad... unless i get wheelhop sometimes then it would jump all over tyhe place
and i thought that because my dad (v8 boy) thought that ity would change when i did that -Matt thanks boi |
| TONS of parts for sale B16, GSR, Type R | Envy_Motorsports | Parts: For Sale/Trade/Wanted | 25 | 10-16-2008 01:08 AM |
| B16 block with mount snapped off | reckedracing | Engine Building | 8 | 04-22-2004 12:31 AM |
| Distributor for b16 NEEDED | CRXproject | Parts: For Sale/Trade/Wanted | 3 | 10-16-2003 10:57 PM |
| Hybrid jdm b16 tranny | crxfreak | HYBRID -> ED-EF / DA | 2 | 06-30-2003 09:55 PM |
| B16 Or Zc In Crx Help Needed | c8r9x_si | HYBRID -> EG-EK / DC | 2 | 01-31-2003 03:14 PM |
