b16 swap
Old 06-13-2004, 04:45 PM   #1
dragon2003 is off the scale
Send a message via MSN to dragon2003 Send a message via Yahoo to dragon2003
well i am planning on doing a b16a1 swap on my 89 civic dx, and i was wondering if i will need anything else besides what the swap comes with. and the swap comes with:
motor
tranny
ecu
axles
shift linkage
stock motor mounts
alternator
starter
clutch
flywheel
intake manifold
exhaust manifold
fuel rail
injectors
distributor
engine harness
all sensors
the swap is only $1,315.00
dragon2003 is offline   Reply With Quote
Old 06-13-2004, 11:20 PM   #2
9inch is off the scale
you'll need.....
hasport shift linkage or shortened 90-93 integra
conversion wiring harness EFDX-VTEC hasport the DX model needs to be converted to si first
hasport mounts/placeracing mounts
axles from 90-93 integra or i used 94 del sol passenger side 86 integra driverside
upper radiator hose 92 gsr trimmed
lower radiator hose 90 integra trimmed or you can find some for the swap on ebay that are made for this swap
if you have a/c you'll need a special braket. i have one for sell that i didn't use, it's from hasport
also buying a crate motor it's always smart to replace spark plugs and wires, all the belts alternator timing. and the WATER PUMP. and it's also a good idea to replace the clutch sense the motor is out of the car, but you don't have to
check out hasports website and place racingwww.hasport.com
www.placeracing.com
9inch is offline   Reply With Quote
Old 06-14-2004, 12:00 AM   #3
Citizen_Insane's Avatar
Citizen_Insane will become famous soon enough
Send a message via AIM to Citizen_Insane
1st, If you haven't already ordered the engine, look into buying from hmotorsonline.com. Steve is a great guy and is considered one of the most reputable dealers in the United States.
I would suggest getting hasport mounts. They DON"T break. Seriously. I've heard one story about them breaking, and many about the HCP/Placeracing/otherweldedcrap mounts.
You can do the wiring yourself, its not really very hard...at all, or if you don't feel comfortable doing it, order a conversion harness. If the swap comes with teg or SiR axles, use those.
Definatly replace the clutch. I found the one inside my b16 was completly bare when I pulled the tranny to install the new clutch.
No tech questions through PM please!
B16 CRX....you will be missed
Citizen_Insane is offline   Reply With Quote
Old 06-14-2004, 01:22 AM   #4
can i just get the dx to sir conversion harness from hasport, instead of changing it over to an si first? why change it over to an si then the sir, when i can just change it over to the sir?
Old 06-14-2004, 08:31 AM   #5
Becuase the DX is DPFI (dual point fuel injected) and the Si and SiR are MPFI (multi point fuel injected). All this means is you need to run wiring for 2 more injectors to get it to Si Spec. Then you need to run 4 wires + a ground for the VTEC conversion to SiR.
Old 06-14-2004, 10:04 AM   #6
CarAudiophile will become famous soon enoughCarAudiophile will become famous soon enough
I can attest to this.. Steve is a great guy.. Alot of us around here have ordered Motors from him.. If there is any problem with the Motor he is very quick to take care of it.. And all motors come in great shape..
And I agree. Do a new Clutch. Its alot easier to do when the motor is out vs doing it later.
CarAudiophile is offline   Reply With Quote
Old 06-15-2004, 12:00 PM   #7
i bought my motor through hmotorsonline as well. they test the compression and also offer a 100% money back garentee. although the garentee is only valid if you replace all the parts i listed above. its not that big a deal though because you need to replace thoughs things anyway. don't forget the water pump from a 94 del sol.
Old 06-21-2004, 12:36 AM   #8
i was wondering, if any of you would know what sensors i would have to use with an obd1 ecu.
Old 06-21-2004, 12:43 AM   #9
or what sensors i would have to get when i convert my obd0 to obd1.
Old 06-29-2004, 09:49 PM   #10
civhatch21 is off the scale
hey i need to know how you did the wiring harness for that swap if you would let me know i would appreciate it i need exact diagrams if you have the thanks my email is civhatch21@aol.com
civhatch21 is offline   Reply With Quote
Old 06-30-2004, 11:01 PM   #11
civhatch21 just go to this site www.deepstaged.net/dxtosir.htm and you will find what you need. good luck and take it easy.
Old 07-01-2004, 02:22 PM   #12
brian11to1 is just really nicebrian11to1 is just really nicebrian11to1 is just really nicebrian11to1 is just really nice
ardperformance.com and http://vtecfrog.com make converison harnesses to run an obd1 ecu with you existing obd0 harnesses
