B16a in CRX- what fuel filter?
Old 04-27-2006, 12:33 AM   #1
Rep Power: 0 theelemental is off the scale
Hi, as the topic says, I have a 1st gen b16a swapped into my 89 CRX hf, and the fuel filter I have on there now is for a 1.5l hf motor. I have been having problems @ high rpms, and have been told it may be due to low fuel pressure. I have a new fuel pump & new filter (for the hf motor), but can I put a larger/higher flow filter on? The filter for a 1991 intergra looks very similar, but is designed for a larger displacement engine...
I guess my question is what filters are you guys using in your b16 swaps, and can I increase fuel pressure by using a larger filter?
Thanks,
Matt
theelemental is offline   Reply With Quote
Old 04-27-2006, 12:53 AM   #2
GSRCRXsi's Avatar
Rep Power: 88 GSRCRXsi is a glorious beacon of lightGSRCRXsi is a glorious beacon of lightGSRCRXsi is a glorious beacon of lightGSRCRXsi is a glorious beacon of light
i have the stock fuel filter running my GSR engine. id say if you "need" another filter get the si one.
91 CRX si
95 Integra LS
Originally Posted by 90 accord
i have a lady, of over a year and a half now, and she likes the plug more
Old 04-27-2006, 10:32 AM   #3
Citizen_Insane's Avatar
Rep Power: 51 Citizen_Insane will become famous soon enough
Send a message via AIM to Citizen_Insane
I'm using an HF filter and have had no problems whatsoever with my b16a
No tech questions through PM please!
B16 CRX....you will be missed
Citizen_Insane is offline   Reply With Quote
Old 04-27-2006, 02:21 PM   #4
Rep Power: 0 Defiant-EG2 is off the scale
Stock fuel filter should be just fine. Once you start upgrading the fuel, then yes, replace it.
94' Del-Sol
Defiant-EG2 is offline   Reply With Quote
