Facebook Twitter
B16A EF Sedan Axle Help
This is a discussion on B16A EF Sedan Axle Help in the HYBRID -> ED-EF / DA forum
Whats up all. Question here about axles. I've got an EF3 Si Sedan (Japanese Import) now it was originally running a ZC as you will know. But I bought an EF8 CRX SiR for the B16A and all the running gear which is now in ...
Old 03-30-2009, 06:23 PM   #1
br-
Default B16A EF Sedan Axle Help
I've got an EF3 Si Sedan (Japanese Import) now it was originally running a ZC as you will know. But I bought an EF8 CRX SiR for the B16A and all the running gear which is now in the sedan. Now i'm using all the CRX axles but the driverside shaft (car is RHD) is slightly too short the bearings just about sit into the cup on gearbox and on full lock one of the bearings will sit halfway out of the cup. So could someone tell me what axle I need exactly, or if theres anything I can do to sort out the problem. I'm also using Innovative Mounts.
Thanks Brian
br- is offline   Reply With Quote
Old 04-03-2009, 11:58 PM   #2
Eli2's Avatar
Maybe this will help you?
Hasport Billet Mounts
Eli
Eli2 is offline   Reply With Quote
90 crx si w/ b16a axle wont release Schock3 Civic and CRX - EF 8 12-06-2008 07:38 PM
ef b16a axle question keg HYBRID -> ED-EF / DA 6 11-12-2007 03:02 PM
AXle Question B16A swap into 92-95 Civic wrmx6 HYBRID -> EG-EK / DC 2 05-10-2006 10:04 AM
Which Axle for B16A sir2? ericL General Tech and Maintenance 9 08-18-2005 06:53 PM
© 2001-2013 HondaSwap.com
