B16a header question.
Old 05-21-2004, 11:08 PM   #1
Rep Power: 12 Floydy is off the scale
Send a message via AIM to Floydy
Ok, a crx with a b16a, is it better to run a header that already has two holes/bungs for the o2 sensors. Like a header from a vtec del sol. Or would it be easier and better to splice the two o2 sensor wires together and just run one o2 sensor, with a crx header?
Daily Driver- 88 Rex with ZC swap. (Soon to have an ls/vtec)
Floydy is offline   Reply With Quote
Old 05-21-2004, 11:14 PM   #2
GSRCRXsi's Avatar
Rep Power: 88 GSRCRXsi is a glorious beacon of lightGSRCRXsi is a glorious beacon of lightGSRCRXsi is a glorious beacon of lightGSRCRXsi is a glorious beacon of light
dont slice the wires together, you need to run 2 o2 sensors. and a del sol vtec header will onlyu have one o2 bung, its obd1. theres a few companies that make headers with 2 o2 bungs for the first gen b16, im pretty sure hasport makes one. or you could get a 4-2-1 header and add the other o2 on.
91 CRX si
95 Integra LS
Originally Posted by 90 accord
i have a lady, of over a year and a half now, and she likes the plug more
Old 05-23-2004, 01:21 AM   #3
Rep Power: 12 9inch is off the scale
i have an 88 crx si with a b16a1 swap and a dc 4 into 1 header with one bung. i just spliced the two together. from what i have read and heard, the car should only run a little rich but no big deal if you have a hand full of other mods or are planing to. i personlally dont think its that big of a deal.
9inch is offline   Reply With Quote
Old 05-23-2004, 07:50 PM   #4
Would a 99 or 2000 si header work?
Old 05-23-2004, 11:39 PM   #5
Rep Power: 28 Bl6CRX is off the scale
Send a message via AIM to Bl6CRX Send a message via Yahoo to Bl6CRX
it will work, has only 1 bung though, i ran a single bung header for awhile before converting to obd1 and i didn't notice a difference during the month that I did...
Bl6CRX is offline   Reply With Quote
Old 05-24-2004, 12:47 PM   #6
Just have a new bung welded into the header...
90 Integra Sedan
B20V 225 / 153
Old 05-25-2004, 12:42 PM   #7
Thanks man. I'll probably weld another bung into a del sol header.
Old 05-26-2004, 11:44 AM   #8
Rep Power: 12 RSBAD454 is off the scale
i noticed that between the years of B16's the exhaust manifolds have subtle differences. I used a 94 Del Sol downpipe with my JDM dual O2 sensor manifold, the Del Sol downpipe stud holes dont line up. i had oblong the down pipe holes to match the manifold stud pattern. I also noticed the JDM 88-91 B16 manifold is thicker looking than the Del Sol manifold and the heat shields arent interchangeable. Just some differences i thought id share.
RSBAD454 is offline   Reply With Quote
Old 05-26-2004, 03:23 PM   #9
thanks man. Thats good to know before I go wasting money.
Old 05-21-2007, 10:36 PM   #10
Rep Power: 11 littlecrxVTEC is off the scale
word
littlecrxVTEC is offline   Reply With Quote
Old 05-21-2007, 10:43 PM   #11
Question
Had the exact same thing happen to me with the downpipe, only I am using a 94 Integra LS downpipe. Had to oblong the flange holes so it would mount to the stock JDM B16a manifold (dual o2).
I'm wondering if the B18a downpipe from 90-93 integra LS will actually FIT onto a B16a obd-0 crx?!
I know that the GSR downpipe is slightly longer than the B16a, but I NEED all the ground clearance I can get!
