b16a into ef sir!
Old 03-16-2009, 07:22 PM   #1
Rep Power: 4 r3alklas1km3x1kanz is on a distinguished road
Question b16a into ef sir!
Help!
i have a b16a and im putting it into my 89 hatch ef sir! I have shift linkage, ecu, mounts. I put the motor in the car but now the wires do not match up im not sure if im supposed to get some extensions or if im missing wires please write back if you could be of any help! Thanks!
also im running a p28
r3alklas1km3x1kanz is offline   Reply With Quote
Old 03-16-2009, 07:27 PM   #2
übber ɐɾuıu etarip
Z6CRX's Avatar
Ride:  1995 BMW 318ti, 1985 Honda VF500F(now legal)
Rep Power: 73 Z6CRX has a reputation beyond repute
Z6CRX has a reputation beyond reputeZ6CRX has a reputation beyond reputeZ6CRX has a reputation beyond reputeZ6CRX has a reputation beyond reputeZ6CRX has a reputation beyond repute
Send a message via AIM to Z6CRX Send a message via Yahoo to Z6CRX myspace  FaceBook
if you have an SiR it will have the wires already in place and you can use the stock mounts for the B16
but if you have the Si you will have to add wires for the knock sensor, vtec, and extra o2 sensor
also if you had a dx/std that was DPFI theres the stuff that needs done like the SI, but you also have to wire for MPFI.
what ECU are you running and what model or engine was in the car previously?
Originally Posted by Celerity View Post
No one hates anyone around here more than people hate Celerity. He's an asshole.
Z6CRX is offline   Reply With Quote
Old 03-16-2009, 07:56 PM   #3
the car is an 89 SIR hatchback...
i previously had a d15b vtec in there and now i dont know why the wires dont match on the b16 but they dont it looks like some are missing im not sure...
Old 03-16-2009, 07:59 PM   #4
übber ɐɾuıu etarip
Z6CRX's Avatar
sounds like your car was converted to OBD1 are all the plugs off the firewall rounded.
worst case use the engine harness of your old motor
What ecu was it running and do you have any pictures of the plugs and and whats not matching up?
If you run OBD1 change the ecu and distributor, and of course you have to do a 4 wire o2 sensor as well. Unless the B16 you got was already obd1.
Old 03-16-2009, 08:04 PM   #5
übber ɐɾuıu etarip
Z6CRX's Avatar
aite basically i got a b16a with tranny, mounts shift linkage, ecu, and pretty much everything but when we put the motor into the car the wires just dont match up im not sure if theres some wires missing or what please let me know i need my car back!
b16a swap into ef sir!
please dont double post the same question
Old 03-16-2009, 08:06 PM   #6
but the b16 is OBD0
Old 03-16-2009, 08:08 PM   #7
übber ɐɾuıu etarip
Z6CRX's Avatar
ok.. then you need to run the OBD0 ecu.
if your running a P28 that is OBD1
So if you have a jumper harness unplug it.
if its hardwired, rewire or buy a jumper(much easier)
and are the engine bay plugs different what plugs are wrong?
Old 03-16-2009, 08:12 PM   #8
is a pw0 obd0?
Old 03-16-2009, 08:14 PM   #9
übber ɐɾuıu etarip
Z6CRX's Avatar
is a pw0 obd0?
does it have different plugs than your p28?
ECU Identification
and yes it should be obd0
Old 03-16-2009, 08:16 PM   #10
ok so i can use the p28 but i have to take the harness around the motor off and then hook up a jumper harness instead right?
Old 03-16-2009, 08:24 PM   #11
übber ɐɾuıu etarip
Z6CRX's Avatar
NO the P28 is either on the jumper now or is hardwired. Since you said its already plugged in or was plugged in for the previous motor.
OBD0 and OBD1 ecu's are do not work with each others distributors.
PWO requires everything to be obd0 which the engine is currently. find a way to properly hook it up to the car. you can use your old engine harness but you will have extra plugs for the o2 which you will likely splice out for the 2 1-wire o2 sensors. then you have to modify the distributor plugs to match up for the obd0 distributor. you will also have to run an injector resistor for the injectors.
P28 (it will need chipped) and you have to replace the distributor with an OBD1 unit and use a 4 wire o2 sensor and wiring a knock sensor if you choose. make sure to run an injector resistor if you run the obd0 injectors
please read a few articles related to swappign in the FAQ section, it will be very usefull to have some backround.
Old 03-16-2009, 08:26 PM   #12
übber ɐɾuıu etarip
Z6CRX's Avatar
also are you in the US or another country?
Old 03-16-2009, 08:27 PM   #13
damn i dont get it haha! but ok my old engine is gone and everything with it! i bought this b16 with everything even the p28 ecu...the pw0 was on my d15b vtec but i already sold it
Old 03-16-2009, 08:29 PM   #14
and i live in cali
Old 03-16-2009, 08:29 PM   #15
übber ɐɾuıu etarip
Z6CRX's Avatar
is your o2 sensor 4 wire?
you need to get a jumper harness for the ECU and run the wires for the o2 and knock sensor.
Old 03-16-2009, 08:30 PM   #16
übber ɐɾuıu etarip
Z6CRX's Avatar
and i live in cali
1. You'll need to get this smog certified if they even allow the swap
2. I REALLY DOUBT YOU HAVE AN SIR. its not even us market.
Old 03-16-2009, 08:33 PM   #17
how would i know if its and sir or not?
Old 03-16-2009, 08:40 PM   #18
übber ɐɾuıu etarip
Z6CRX's Avatar
VIN for one.
(my starting vin may be off but your looking for ED/EF)
JHMED is not SiR
JHMEF is a good chance of being an Sir
that too it had a d series in it, they only came with B16's. not to mention wrap around corner lenses and a whole list of other features. If your mounts are aftermarket, they wont have the same symmetry as the Sir mounts and wont bolt up.
only way to get them here are as grey market imports really, or conversions.
Old 03-16-2009, 11:53 PM   #19
Rep Power: 11 BrokenRex has a spectacular aura aboutBrokenRex has a spectacular aura aboutBrokenRex has a spectacular aura about
someone stuck an SiR badge on your hatch, let it go and focus on the problems at hand...
BrokenRex is offline   Reply With Quote
Old 03-16-2009, 11:56 PM   #20
übber ɐɾuıu etarip
Z6CRX's Avatar
he's been messaging me on yahoo, trying not to clutter up this for random questions. It is an Si model though for sure.
pretty much he accidentally kept his p28 off his old car and he has at least 1 1-wire o2.
I'm still trying to figure out if the distributor is OBD0 or 1 and if there's a conversion harness on the ecu plugs or not.
Old 03-16-2009, 11:59 PM   #21
if the plug is cream colored, it's obd0, if it's grey it's obd1. the plugs for the ecu should be easy, if there's three, obd0, if there's two, it's obd1. (i'm sure you already know this, maybe it'll get him thinking on the right track however)
Old 03-17-2009, 12:03 AM   #22
übber ɐɾuıu etarip
Z6CRX's Avatar
i forgot about it being three plugs. i just remembered the shapes and sent him some pics of the main plug to find out which was which.
obd0 round
obd1 rectangular
im still waiting on which plugs aren't plugging in, and still waiting to find out about an injector resistor.
if he doesn't have one i think OBD1 LS injectors are the same size, but thats later.
Old 03-17-2009, 12:06 AM   #23
you're the most helpful person ever, that's a lucky guy there to have your help on his first swap. i did mine in my driveway with no hoist and no internet access about 6 years ago. i'd have killed to have someone walking me through the process. if i could rep you again i would.
Old 03-17-2009, 12:15 AM   #24
übber ɐɾuıu etarip
Z6CRX's Avatar
I had some help from reckedracing here when I did my first swap (along with an OBD1 conversion rewired by hand the hard way). Occasionally I try to help out like he did, because I have learned a lot since then.
I would rep for your earlier post but i have to spread it around :-p
Old 03-17-2009, 12:46 AM   #25
old sckool enthusiast
OGMatt's Avatar
Ride:  89' CRX Si
Rep Power: 47 OGMatt has a brilliant futureOGMatt has a brilliant futureOGMatt has a brilliant futureOGMatt has a brilliant futureOGMatt has a brilliant futureOGMatt has a brilliant futureOGMatt has a brilliant futureOGMatt has a brilliant futureOGMatt has a brilliant future
didnt know ther was such thing as 89 sir's
shaved sig
OGMatt is offline   Reply With Quote
Tags
b16a, b16a swap, civic, ef sir, hatchback, honda, sir, swap, wiring
Please Help!!!! b16a head b16a block w B18b crank, eagle rods, and je 83mm pistons KME99Si Engine Building 1 11-02-2008 03:19 PM
B16a timing belt covers b16a vtec jdm honda acura RSS-Bot Auctions 0 10-02-2008 05:36 PM
B16a timing belt covers b16a vtec jdm honda acura RSS-Bot Auctions 0 07-21-2008 06:03 PM
B16a timing belt covers b16a vtec jdm honda acura RSS-Bot Auctions 0 07-14-2008 04:17 PM
B16a Timing Belt Covers B16a Vtec Jdm Honda Acura RSS-Bot Auctions 0 05-28-2008 10:23 PM
