b16a issues
gene
Hi there I have a 1st Gen b16a (PR3) in a 89 Si and I seem to have a problem where when I maintain a certain throttle load the car seems to bog/feel flat until I give the car some gas and it goes back to normal. I heard that the common problem would be the primary and secondary 02 sensor wires mixed up. I re-wired the two so that C8 and C16 are going to the proper sensors. But the problem remains. I get no codes and when I disconnect the 02 wires I get no ECU code either. Any insight would be helpful. Thanks for your advise in advance.
:blink:
P.S. All new vacuum lines and new map sensor recently put in
I would personally convert to OBD1, its very simple and pretty inexpensive.
I hate the way OBD0 pr3's run a car. They just seem harder to get to run properly.
All you need is:
OBD1 P30 or Chipped P28 ECU ~ $150
DOHC VTEC OBD1 Dizzy ~ $150
OBD0-OBD1 Jumper Harness ~ $100
4-Wire o2 Sensor ~ $20
Plus, Sell all of your stuff for like $225 so you'll end up putting like $225 in to it.
[I have had these problems before, and when I unplugged the o2's it ran fine, I would just get a CEL when I de-accel for a very long time. When that happened I just kicked the key off and back on real quick and never had any problems.
do u have access to a fuel pressure guage? i ran into a similar problem with an 88 hf w/ b16a. only putting out like 20lbs of pressure at the fuel rail. check voltage at pump connector-more resistance means less voltage and under powered pump. this one ended up needing a new pump. did this problem just start overnight or something that gradually got worse and worse?
My 1st gen b16 does the same thing. If I maintain the throttle for a while and then get on the accelerator, it hesitates and spudders. I've seen this posted a few times here on HS and never have I heard of a solution that worked :dry:
Quoted post[/post]]
:werd:
Mine does the same thing.
Its the comp. the stock obd0 comps dont really care about the O2 sensors. I unpluged mine and drove for a week till i got a cell. right now i have the second O2 sensor tapped into the first sensor and still no cells. my b16a does this too. what speed/rev were you at? my b16 doesnt like to be driven under 3000 rpm. But I also have the time retarded 2 for the N2O
