B16a to LS/Vtec
Old 02-25-2009, 10:49 PM   #1
burninriceinva's Avatar
Ride:  Swapped 91 CRX
Rep Power: 6 burninriceinva is on a distinguished road
Cool B16a to LS/Vtec
I swapped a b16a into my 91 crx damn over two years ago where does the time go. i just picked up a b18a block that has been rebuilt with arp rod bolts, p30 pistons, and bored to 82 mm. i have two questions is the 82 mm bore to much for the stock sleeves will this cause a problem later on and will the breather chamber, water pipe, water pump, thermostat housing and so on from the b16a transfer to the b18a block. i know i have to get a gsr or tyre r timing belt and of course a new oil pump. i just wanted to know if i needed to order theses parts for the LS block. Thank for all the help i have received you guys got me though the first swap.
burninriceinva is offline   Reply With Quote
Old 03-01-2009, 08:52 PM   #2
is anybody put there?
Tags
b16, b16a, b18, b18a1, crx, swap
B16a timing belt covers b16a vtec jdm honda acura RSS-Bot Auctions 0 10-02-2008 05:36 PM
B16a timing belt covers b16a vtec jdm honda acura RSS-Bot Auctions 0 07-21-2008 06:03 PM
B16a timing belt covers b16a vtec jdm honda acura RSS-Bot Auctions 0 07-14-2008 04:17 PM
B16a Timing Belt Covers B16a Vtec Jdm Honda Acura RSS-Bot Auctions 0 05-28-2008 10:23 PM
2000 ITR Integra Vtec head B18C5 B18C B16A LS/Vtec RSS-Bot Auctions 0 12-24-2007 11:23 AM
