B16a swap
Old 08-12-2007, 05:11 PM   #1
keg
Rep Power: 7 keg is on a distinguished road
Exclamation B16a swap
I started swap in week end b16a from a crx 91 to 89 ef civic was informed it was a straight swap but got motor in and the mounts on b16a are thicker than my zc do i just stretch my mounts apart and the rear one looks like its miles out?
keg is offline   Reply With Quote
Old 08-12-2007, 06:14 PM   #2
FüK-VTEC
civicious's Avatar
Ride:  07 Nissan Frontier, 90 CRX Si, 06 ZX6R racebike, chopped-out 02 Yamaha V-Star
Rep Power: 189 civicious has a reputation beyond reputecivicious has a reputation beyond repute
civicious has a reputation beyond reputecivicious has a reputation beyond reputecivicious has a reputation beyond reputecivicious has a reputation beyond reputecivicious has a reputation beyond reputecivicious has a reputation beyond reputecivicious has a reputation beyond repute
Send a message via AIM to civicious myspace
No. You buy the correct mounts for that swap. Hasport Performance, Inc.
period. end of story.
/thread
CMRA #265
http://www.myspace.com/civicious
AIM: greyfades
civicious is offline   Reply With Quote
Old 08-13-2007, 07:26 PM   #3
Walterronny's Avatar
Rep Power: 7 Walterronny is on a distinguished road
what about imnovate mounts? they make for B16 swap too
Walterronny is offline   Reply With Quote
Old 08-13-2007, 07:54 PM   #4
Brutal Moderator
BrutalB83's Avatar
Ride:  97 Integra LS Coupe
myspace
The innovative mounts will work as well. Just make sure you get mounts designed for this particular swap. Don't try to ghetto rig your factory mounts to make it work, that's a bad idea.
PSN Network ID: BrutalB83
Old 08-13-2007, 10:38 PM   #5
FüK-VTEC
civicious's Avatar
In a USDM EF, your only options for a B-series swap are aftermarket mounts unless you want to do a lot of cutting and welding.
CMRA #265
AIM: greyfades
Old 08-13-2007, 10:50 PM   #6
keg
i am in nz so it is a jdm
Old 08-15-2007, 06:52 PM   #7
keg
what do you do with speedo cable the zc was cable the b16a is digital
Old 08-15-2007, 07:15 PM   #8
jlicrx's Avatar
JDM Civic with ZC is EF3 - JDM Civic with B16A is EF9 - different chassis - still need aftermarket mount kit - B16A will not bolt into EF3 chassis
ZCspeed Racing
Old 08-27-2007, 09:21 PM   #9
keg
can i use the inner axels from crx will they mate with the ef and is the rear mount on the motor will that work or will i need 91 teg mount?
Old 08-28-2007, 02:09 PM   #10
Andrew's Avatar
Ride:  1991 CRX Si
Rep Power: 47 Andrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to behold
Send a message via AIM to Andrew
No. You need to use LS axles/midshaft.
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 08-28-2007, 07:21 PM   #11
keg
what about rear mount?
Old 08-29-2007, 07:49 AM   #12
Andrew's Avatar
Ride:  1991 CRX Si
If you use a Hasport kit, you should be able to use w/e mount is on there.
They are all the same(B-series). LS might be cheaper though...
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 09-11-2007, 04:52 PM   #13
Banned
Ride:  88 honda crx si
Rep Power: 0 1988hondacrxsiR1 can only hope to improve
The mounts have thicker bushing to reduce vibration so it should fit and do not use stock mounts they will break. What is goal with the b16? NA or FI
1988hondacrxsiR1 is offline   Reply With Quote
For Sale b16A 1st Gen full swap some extras importdj Parts: For Sale/Trade/Wanted 14 10-04-2009 12:06 AM
CRX / 88-91 Civic Hatch B16a swap timeslips? The_MATRIX Racing and Driving Techniques 19 06-18-2007 03:56 AM
b16a swap shifter linkage. sleeper88 Civic and CRX - EF 1 11-25-2006 09:41 AM
FS B16a tranny, b16a head, Tons of swap parts!!!! WannabeSI Parts: For Sale/Trade/Wanted 9 05-20-2004 10:53 PM
JDM B16A OBD1 Swap in 95 Civic EX CivicSiR7 HYBRID -> EG-EK / DC 4 02-13-2004 07:26 PM
