Facebook Twitter
B16A Swap Problems
This is a discussion on B16A Swap Problems in the HYBRID -> ED-EF / DA forum
A good friend of mine blew up his EF last week (shifted from 4th to 1st on the highway). He needed a commuter so I sold him my old B16A swap that was in my CRX. Everything performed well in the CRX. His car is ...
Old 06-11-2012, 04:01 PM   #1
GlassHeadlights's Avatar
Default B16A Swap Problems
His car is a '90 Civic DX.
-MPFI conversion
-OBD0 to OBD1 conversion
-Stock P30 ECU
NO CHECK ENGINE LIGHT
The motor will idle fine and rev up to about 3-4k RPM then just sputter and not rev any higher.
The main relay only kicks in when you tap it so were going to change that. We will also try a new fuel filter.
What else could it be?? I think ignition problem or fuel delivery...
R.I.P. Short Lived '95 DC2 GSR http://hondaswap.com/auto-multi-medi...8/#post1722934
'93 Civic Coupe Si http://hondaswap.com/auto-multi-medi...5/#post1727322
Originally Posted by invisibledemon View Post
..we generally don't take each other too seriously here.
GlassHeadlights is offline   Reply With Quote
Old 06-11-2012, 04:05 PM   #2
xj0hnx's Avatar
Limp mode? Knock sensor?
xj0hnx is offline   Reply With Quote
Old 06-11-2012, 04:13 PM   #3
P06 ECU converted to P28 then chipped for a P30. Knock sensor is deleted on the chip. It ran great on the donor car.
Old 06-11-2012, 04:38 PM   #4
CAFROG's Avatar
Check engine light bulb is still working?
Reads like a limp mode....that's why I asked about the bulb still good on this hatch.
Check MPFI wiring (if only the integrity of the connections)
CAFROG is offline   Reply With Quote
Old 06-12-2012, 12:22 AM   #5
Turned out to be bad gas. We drained the tank, filled up on premium and put in some injector cleaner. The powerband still doesn't feel right so were doing the fuel filter tomorrow.
Crx si with B16a swap Having problems 1989crxsiB16A Civic and CRX - EF 4 06-13-2012 05:16 PM
B16a swap 92-95 problems, please help... 92eg9333 HYBRID -> EG-EK / DC 3 03-30-2009 10:50 PM
b16a swap problems 1994delsolLS Members' Lounge 11 09-12-2008 06:26 PM
DX to B16A swap problems crxdxb16a HYBRID -> ED-EF / DA 8 06-30-2005 02:36 PM
B16a Swap Problems / Need Help magnum000 HYBRID -> EG-EK / DC 2 02-23-2003 10:22 PM
© 2001-2013 HondaSwap.com
