| | LinkBack | Thread Tools |
| | #1 |
| Junior Member | I have a 89 si crx (whitch did have a D16 in it). I just bought a b16a from japan. The Engine wire conectors are not the same as the crx ones. On the left side The intack side the engine has 3 round conectors 1 big 1 med 1 small. THe other side of the engine has a 1 med and one for the injetor resiter(which this one matches). On the Crx intack side it has a 1 Big conecoor 1 big square and 1 little square. I was wonding if some one could tell me where i could find a convertion kit or info on all the wires so i could make my own. I still have all the concetors from the old engine and the old car from japan. So if i know what the wire where i could just hook them up right. THanks |
| | #2 |
| Junior Member | use you stock D16 harness and amke it work like adding the VTEC SOl wire, VTEC pressure switch, and Knock sensor. Hopefully you have a very good honda tech or someone who has a clue on what they are doing if you do need help. |
| wiring for b16a | dok | ECU's, Electronics, and Tuning | 2 | 10-17-2006 11:33 PM |
| Intergra Wiring Harness On A Jdm Sir2 (b16a) | delsolsir2 | HYBRID -> ED-EF / DA | 5 | 06-05-2003 09:00 PM |
| Swap B16a Into Crx, Need Wiring. | joeblack | HYBRID -> EG-EK / DC | 2 | 04-16-2003 11:32 AM |
| Honda B16a Wiring Problem | rdsnrthms | HYBRID -> EG-EK / DC | 2 | 03-28-2003 01:20 AM |
| 86 Crx Dx Wiring Convertion For Zc | ne1469 | ECU's, Electronics, and Tuning | 1 | 02-11-2003 01:56 AM |
