Hello hows it goin? my first post on here from the UK. [img]style_emoticons/<#EMO_DIR#>/cool.gif[/img]
Little background on my car, i have swapped in a B18C1 running a B16A1 head and cable transmission no PAS/ABS/Aircon. I am getting a juddering like 'wheel wobble' when i take left hand corners or in a straight line but not as bad in a straight line as around the bends, turning right there is no vibrations at all and can take them at any speed but turning left its bad at lowish speed. The knocking/juddering increases with speed also. The car is RHD as im from the UK just to make this clear. Any help guys? oh and i will get some pics up later on. Cheers Kenny |
#2 | |
is your axle busted? did you remove the dust seal from the hub?
91 CRX si 95 Integra LS I DO NOT answer tech questions via PM. Use the forums!!! Quote:
get a free flatscreen, yes it works! Please give what you can to the Tom Cote Medical Fund http://honda-tech.com/zerothread/1828476 |
Yes mate i have removed the dust seal from the hub and the axle is in very good condition as are the CV's i have gone over everything i can think of i just thought there may be someone on here that has had similar probs.
check the front cross member? it might be lose. . . . orrrr check the brake rotor and those lil screws that are attaching it to the hub. . . some times if those are lose things can rattle
89 EF build: Poorman's ITR 95 GSR bottom end, .25over b16 pistons Pr3 Zealautowerks compression = 11-8-1 ARP head studs, Stock head gasket S2 Pro series IM, w/ Hondata intake gasket Holley 68mm throttle body ITR 4-1 header, w/ 2.5 in magna flow exhaust ( sounds niceeeee btw) kteller 2.5 mandrel bend kit. PnP b16 head w/ dual valve springs and ITR cams Milled about .030 AEM hybrid CAI Running obd1 w/ p28 tuned on chrome Made 178 at churches w/ 2in exhaust and dc 4-2-1 header w/ 2 in collector. |
#5 |
HS Troll...And Mod
Ride: 2001 Honda S2000
werd on the brakes...check the screws and the calipers...sometimes that stuff just wiggles. if its not the CVs thats the only thing i could think of.
If you PM me with tech questions, you better have a link to the thread in your PM. Need engine Components? -- Call Us. Tell them Fritts sent you and they will cut you a deal you will have to hear to believe. |
