B18 Turbo 88 Crx
Old 11-18-2007, 05:53 PM   #1
Rep Power: 8 Ted O is off the scale
Default B18 Turbo 88 Crx
So heres the plan, to put a b18, into my crx, I have a couple questions!
I plan on running an lsd tranny, heres the question, what clutch should I run? and where do I get the lightened flywheel?
Should I do a turbo kit? or build it up myself?
Also, If I just buy a motor from hmotorsports. (b18), Should I do anything to it to run boost? if not, how much boost can I use.
Thanks!
Ted O is offline   Reply With Quote
Old 11-18-2007, 05:58 PM   #2
Sonnova Bitch!
daveholiday's Avatar
Ride:  2006 GSX-R 600, 2003 Santa Fe GLS
Rep Power: 44 daveholiday has much to be proud ofdaveholiday has much to be proud ofdaveholiday has much to be proud ofdaveholiday has much to be proud ofdaveholiday has much to be proud ofdaveholiday has much to be proud ofdaveholiday has much to be proud of
Send a message via AIM to daveholiday  FaceBook
Infamous questions: What are your power goals, and what kind of budget do you have? Figure out what those are and go from there. Most of the time, building your own turbo kit is cheaper, so I guess it depends on what you feel like spending.
daveholiday is offline   Reply With Quote
Old 11-18-2007, 06:18 PM   #3
Sorry, posted that quick before I ate, had plans to add more.
My goals are daily driver, leaning toward race more than comfort.
Im not sure on power goals, Id like to get the best bang for the buck, and im looking to spend around 3-6 grand. Possibly more if I can get alot more power for a little more money.
The car right now is a dx, has the stock 1.5 in it, If I could find a cheap b18 in iowa, I would then have more cash for the turbo setup. (3-6 grand includes the motor....)
Old 11-18-2007, 07:57 PM   #4
Sonnova Bitch!
it seems like finding a cheap old beat integra would be easier than finding the motor. Try for both, but also try to find an old 90-92 or something teg, and do the work yourself.
Old 11-18-2007, 08:09 PM   #5
Find an older integra and rebuild the motor? or what you mean?
Old 11-18-2007, 09:54 PM   #6
donny_ptrsn's Avatar
Ride:  GT avalanche 2.0 (my MTB)
Rep Power: 6 donny_ptrsn is on a distinguished road
Send a message via AIM to donny_ptrsn myspace
yeah find the teg and then build it up but don't swap it in till the motor and everything is done. strap the turbo on tune YES MAKE SURE YOU TUNE IT. and then see how much boost you want to run and then one of the most important things is make sure you have funn doing it! good luck.
donny_ptrsn is offline   Reply With Quote
T3/T4 Twisted Ram Full Race Turbo Kit INTEGRA B16 B18 RSS-Bot Auctions 0 11-14-2007 12:53 AM
450CC Injectors DSM TURBO Acura Honda Civic CRX B16 B18 RSS-Bot Auctions 0 11-09-2007 04:13 PM
CARB Legal Turbo Kits for a b18?..... LSCRX Forced Induction 2 10-09-2007 10:01 PM
Turbo Charging 88-91 Preludes 1Funryd Turbo Information 0 12-09-2006 01:03 AM
Is there a Supercharger kit chap_e77 Forced Induction 3 08-26-2003 07:09 PM
