B18a to B18c (V-TECH) in a '91 LS Integra
Old 10-15-2004, 04:07 AM   #1
Rep Power: 0 Jospec is off the scale
If I am correct, a stock '91 LS comes with a B18a. How much difference is there (in size and performance) in a B18c V-TECH motor. If it would even be possible to switch it out, would it be worth it? (Used kit goes for $4950 @ http://www.nippon-motors.com/Performance%20Engines.htm) Also is it possible to bore out the heads any more? (apparently it won't work because the aluminum casing or something but I just wanted to be sure)
Jospec is offline   Reply With Quote
Old 10-15-2004, 05:06 AM   #2
I'll be back...
B16RacerN2NR's Avatar
Ride:  06 Mazda 5, 91 Civic DX
Rep Power: 156 B16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond repute
B16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond repute
Send a message via AIM to B16RacerN2NR myspace
i'm not gonna comment on the VTECH thing cuz someone else is just going to flame your ass for it later anyway. as far as size goes, the b18a is actually bigger than the b18c. performance wise, it is a lot better. boring out the head??? do you mean porting it?
Real Eyes Realize Real Lies
B16RacerN2NR is offline   Reply With Quote
Old 10-15-2004, 10:00 PM   #3
B18C1 = 1797 CC's - 170 HP
B18A1 = 1834 CC's - 140 HP
If you get an OBD1 B18C then its just a matter of wiring the VTEC and replacing the GSR intake manifold with a Skunk2 Unit... Using the Stock Integra Tranny, axles and mounts it will slide right in.
Since you have a 91 integra (obd0) you may want to find a PR3 or PW0 ECU... or convert to OBD1 using a P72 ECU...
90 Integra Sedan
B20V 225 / 153
Old 10-15-2004, 10:34 PM   #4
Rep Power: 43 vtecsir1 will become famous soon enough
V-T-E-C
vtecsir1 is offline   Reply With Quote
Old 10-17-2004, 01:23 PM   #5
sohcslammer's Avatar
Rep Power: 35 sohcslammer is an unknown quantity at this point
Variable Valve Timing and Electronic Lift Control
NO MORE EXCUSES!!!!!!!
Latest project -
1 fucking fast 99 SI
sohcslammer is offline   Reply With Quote
Old 10-17-2004, 01:39 PM   #6
Ride:  Boosted B16 in ej1
Rep Power: 26 driverunknown is on a distinguished road
Send a message via AIM to driverunknown
Originally posted by sohcslammer@Oct 17 2004, 12:23 PM
Variable Valve Timing and lift Electronic Control
I fixed it for ya
The swap is completed. Dented oil pans will kill vtec.
Now boosted!
Vouches:
Wanderinman
driverunknown is offline   Reply With Quote
Old 10-17-2004, 02:05 PM   #7
Originally posted by driverunknown+Oct 17 2004, 12:39 PM--><div class='quotetop'>QUOTE(driverunknow n @ Oct 17 2004, 12:39 PM)</div><div class='quotemain'><!--QuoteBegin-sohcslammer@Oct 17 2004, 12:23 PM
Variable Valve Timing and lift Electronic* Control
I fixed it for ya
[/b][/quote]
It's early.
Latest project -
Old 10-17-2004, 03:18 PM   #8
Ninja Member
Cashizslick's Avatar
Rep Power: 117 Cashizslick has a reputation beyond repute
Cashizslick has a reputation beyond reputeCashizslick has a reputation beyond reputeCashizslick has a reputation beyond reputeCashizslick has a reputation beyond reputeCashizslick has a reputation beyond reputeCashizslick has a reputation beyond reputeCashizslick has a reputation beyond reputeCashizslick has a reputation beyond repute
VTECH = Phone
Vtec = honda motor
Originally Posted by Canadian Finance Minister Jim Flaherty
the recent public policy of privatizing profits and socializing losses is unacceptable to taxpayers
Cashizslick is offline   Reply With Quote
Old 10-17-2004, 04:13 PM   #9
Im sure he gets it... everyone can stop adding thier .02 cents now...
If you need anymore help, feel free to post...
90 Integra Sedan
B20V 225 / 153
Old 10-17-2004, 05:37 PM   #10
Rep Power: 20 97CTR is off the scale
I haven't heard very good things about nippon motors either.
97 ex coupe
Wire tuck in progress....
97CTR is offline   Reply With Quote
