b18a1 into 89 crx si
Old 08-29-2007, 11:56 PM   #1
frosty is off the scale
Default b18a1 into 89 crx si
i bought a 1993 integra ls as a parts car and plan on doing a swap soon. as far as wiring, i was wondering what the best option would be. i already have the obd1 harness and ecu, so should i just swap the injector/distributor plugs on the crx harness and then get a jumper? or is there another alternative that i'm missing? thanks in advance
frosty is offline   Reply With Quote
Old 08-30-2007, 09:27 AM   #2
jlicrx's Avatar
jlicrx has a brilliant future
you don't need to swap the injector plugs to use the OBD1 injectors - you have 2 options, remove the injector resistor box from the sytem and use the OBD1 injectors or keep the resistor box and use the OBD0 Si injectors - just get the distributor jumper for the OBD0 Si distributor to the OBD1 distributor or you could swap OBD1 distributor connectors onto your Si harness
Old 09-11-2007, 06:56 PM   #3
Banned
Ride:  88 honda crx si
1988hondacrxsiR1 can only hope to improve
for eg you do not need resistor box for ef you do need resistor box
and all honda civic and crx injectors are 240cc
1988hondacrxsiR1 is offline   Reply With Quote
Old 09-11-2007, 06:57 PM   #4
Banned
The JDM injectors are also the same in case you wanted to know. GOOD LUCK!
FS in KY: 89 b18a1 dx hatch + extras khrys771 Vehicles: For Sale/Trade/Wanted 1 03-11-2007 11:31 PM
b18a1 swap in 92 civic hatch. brush ECU's, Electronics, and Tuning 2 11-02-2006 04:33 PM
Need Help With B18a1 OBD0 Engine Into 96 Honda Civic EX CSHornet60 HYBRID -> EG-EK / DC 28 07-03-2006 12:53 PM
B18A1 and B18B1 differences, and OBD0 and OBD2 ???'s psychochicken HYBRID -> ED-EF / DA 4 06-16-2006 02:38 PM
Need Help With B18a1 OBD0 Engine Into 96 Honda Civic EX CSHornet60 ECU's, Electronics, and Tuning 1 06-15-2006 03:49 PM
