B18a1 swapped crx wiring help needed
Old 11-13-2005, 06:00 PM   #1
ryangt is an unknown quantity at this point
Send a message via AIM to ryangt Send a message via Yahoo to ryangt
Angry
i have a 91 crx that was a dx, I converted all the wiring over to 89 HF
i have a 91 b18a1 in the car, my real problem is
that solenoid pack on the firewall, has a two pronged connector, comming out of one solinoid, the crx hf wiring harness has a 4 prong connector that supposed to plug into the same place.
is there a way to convert this to fit or what?
this is pretty much the ast thing i need to do.
ive seen on some of the older dual point motors, they had a 4 prong going to their solinoid pack. but those are on dual point motor.
any help is very much appreciated, this is killin me here
2001 Civic EX 2dr, shes beautiful, soon to be turbo.
1991 Crx dx Ls MONSTER BUILD ys1 trans its a beast.
ryangt is offline   Reply With Quote
Old 11-13-2005, 06:46 PM   #2
anyone know what im talkin about ? i tried seraching but nothing seems to be metioned about this problem.
Old 11-14-2005, 12:40 PM   #3
90sihatch's Avatar
90sihatch is off the scale
<div class='quotetop'>QUOTE(ryangt @ Nov 13 2005, 06:46 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
I just have the civic one hooked up and one of the holes on the back of the i.m plugged.
90sihatch is offline   Reply With Quote
Old 11-14-2005, 02:05 PM   #4
is there any way you could send me some pics for reference? I really appreciate the help
Old 11-14-2005, 04:10 PM   #5
jlicrx's Avatar
jlicrx has a brilliant future
<div class='quotetop'>QUOTE(ryangt @ Nov 13 2005, 05:46 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
i know what you are talking about - the Calif DX has EGR valve with box on the firewall like on on HF - you are talking about the Purge Control Solenoid which on the DX has 2 wire connector with 1 green wire and 1 black/yellow wire - the HF has a 4 wire connector with 2 black/yellow, 1 red and 1 green - 1 black/yellow and the red go to the EGR Valve from the Purge Solenoid connector (piggy-backed, so to speak) - for the purge, you only need the 1 black/ yellow and the green - swap the other side of the 2-wire DX connector onto the harness but only use the green and 1 black/yellow wires or swap the solenoid side of HF connector onto the solenoid wires using only the green and black/yellow or just hard wire it - green to green and black/yellow to black/yellow (you probably will never be taking it out anyway, so just hard wire it)
ZCspeed Racing
Old 11-16-2005, 02:58 PM   #6
how much harder, is it to just run the hf solenoid pack?
anyone have a wiring diagram? or a vacuum diagram about that install?
thanks for that great help its right on the money
Old 11-16-2005, 08:51 PM   #7
jlicrx's Avatar
<div class='quotetop'>QUOTE(ryangt @ Nov 16 2005, 01:58 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
yes, you could run the HF setup - your B18 doesn't have EGR, does it? without EGR, you only need 2 of the things in the box: the MAP sensor and the Purge Control Solenoid - the other 2 are for the EGR - the MAP should just plug right in - if you use the HF setup, your HF harness will plug right in - the MAP has a vacuum line from the port on the throttle body projecting out toward passenger side (one closest to front of car) - the purge has vacuum line from intake manifold to the bottom of it and another one from the side to the charcoal cannister - the B18A1 has another solenoid which the DX or HF doesn't have - it is the Fuel Pressure Regulator Control Solenoid Valve - i am not sure if you need it in order to pass emissions in CA
ZCspeed Racing
Old 11-17-2005, 11:14 AM   #8
man thanks alot youve been a real help, im gonna take the two wire and hook it up hopefully it works,
thanks a ton for thepics they are a big help
thanks
