B18B1 problems tranny problems... Clutch maybe?
Old 07-22-2006, 02:33 AM   #1
Rep Power: 7 office888 is an unknown quantity at this point
Default B18B1 problems tranny problems... Clutch maybe?
Okay, for my engine, I choose to buy a kit from the company "Innovative Mounts". Well, I've got their Hydro mount kit with the Hydro-to-Cable adapter for the CRX, and I was pondering something over.
The cable clutch arm on my D16A6 moves free, I can lift it with one finger. The clutch in the D16A6's tranny was perfect still.
If I pull on the cable actuator or push on the clutch arm thingee on the B18B1's, it won't budge at all, no matter how much force is put into it. The B18B1 has the standard 94 Integra LS Hydro Y80/S80 hydraulic tranny on it. The Engine/Tranny was taken out of a rollover Integra.
Is this a problem?
EDIT:
For further information, the motor was sitting in a used car dealer's backyard for about a month. It was taken out of a car someone rolled on a test drive. It then sat in my carport for about 2 months, then was moved into my garage for about 3 months. It's now IN the CRX.
office888 is offline   Reply With Quote
Old 07-22-2006, 07:38 AM   #2
take pictures of the part that isnt working please.
90 Integra Sedan
B20V 225 / 153
Old 07-23-2006, 08:14 PM   #3
Old 07-26-2006, 08:46 AM   #4
bump for a reply! Would like to know the problem before I remove and reinstall the engine for the 4th time in two weeks.
Old 07-26-2006, 09:02 AM   #5
the one of hte left is where the old slave cylinder mounted as well as a mount too, if im not mistaken. as far as your conversion kit not working, i dont know. i know endyne tried to use both the hasport and some compnay out of cali (probably innovative)'s conversion kit, both sucked dick and needed a shit load of modification to work proeperly. ill ink you a little later so you read what he had to do to get it to work right.
90 Integra Sedan
B20V 225 / 153
tranny or clutch ??? which is bad ?? cxcivicgsr General Tech and Maintenance 8 07-01-2007 11:47 AM
Integra Ls tranny code...(b18b1 tranny code) quickersilv3r HYBRID -> EG-EK / DC 2 04-01-2004 01:54 AM
Tranny Problems seerx HYBRID -> EG-EK / DC 0 04-22-2003 10:16 AM
Zc Tranny Problems. hardweapon HYBRID -> EG-EK / DC 1 03-24-2003 11:07 AM
Clutch Problems Racin'WithRice General Tech and Maintenance 3 03-15-2003 03:41 PM
