I have some questions on this swap. My first is is the wiring from obd-o to obd-1 extremely difficult? My second is where can i get a complete swap or am i gonna have to piece it together? I hope you guys take the time to answer my questions. Thank you
#3 | |
Jason
<span style=\'font-size:14pt;line-height:100%\'><a href=\'http://www.jkobd.com\' target=\'_blank\'><span style=\'color:red\'>Brand New OEM OBD Conversion Harnesses.</span></a> <a href=\'http://www.jkobd.com\' target=\'_blank\'><span style=\'color:blue\'>Custom Ecu conversion harnesses, chipped ecus, custom engine harnesses</span></a></span> |
the swap... check Hmotorsonline.com or ardperformance.com
90 Integra Sedan B20B - BROKEN LSVTEC - BROKEN PMTR - running strong! I DO NOT answer tech questions via PM. Use the forums!!! |
#5 |
Jason seems to have quality stuff; buy a conversion-harness from him. That will make your swap plug and play.
<a href=\'http://home.comcast.net/~projectxspeed/3rdgenteg.htm\' target=\'_blank\'>A Project in Progress</a> Get your ECU CHIPPED / buy ECU's CHEAP (uberdata, custom ecu maps, and more): <a href=\'http://www.hondaswap.com/forums/index.php?act=Msg&CODE=04&MID=36429 \' target=\'_blank\'>PROJEKTEG</a> |
