B18C JDM Throttlebody question
Old 02-07-2005, 12:00 AM   #1
Rep Power: 11 seephor is off the scale
There appears to be a vacuum port right under the MAP sensor on the throttle body. I don't know what that hooks up to and I checked my helms and that port doesn't exist on the USDM B18C1 throttlebody. The car runs fine with it being open and there appears to be very very slight vacuum on it by a finger test. I just have it capped off since nothing hooks up to it on the GSR. What is this port and do i just keep it capped off?
seephor is offline   Reply With Quote
Old 02-07-2005, 12:18 AM   #2
FüK-VTEC
civicious's Avatar
Ride:  07 Nissan Frontier, 90 CRX Si, 06 ZX6R racebike, chopped-out 02 Yamaha V-Star
Rep Power: 188 civicious has a reputation beyond reputecivicious has a reputation beyond repute
civicious has a reputation beyond reputecivicious has a reputation beyond reputecivicious has a reputation beyond reputecivicious has a reputation beyond reputecivicious has a reputation beyond reputecivicious has a reputation beyond reputecivicious has a reputation beyond repute
Send a message via AIM to civicious myspace
um...i think it's shit for your EVAP purge canister thingie...I'm pretty sure it's where that braided nylon orange hose thingie goes. It isn't important.
CMRA #265
http://www.myspace.com/civicious
AIM: greyfades
civicious is offline   Reply With Quote
Old 02-07-2005, 12:21 AM   #3
I have the evap purge hooked up on the intake manifold where it's supposed to go.
Old 02-07-2005, 12:32 AM   #4
FüK-VTEC
civicious's Avatar
Do you have a weird orange braided nylon-lookin hose coming off the intake manifold? Cuz I'm pretty sure it's supposed to go on the throttle body.
CMRA #265
AIM: greyfades
Old 02-07-2005, 12:45 AM   #5
no I don't. Although the port where the evap purge went to is smaller on the JDM intake mani compared to the USDM one. Maybe that smaller port on the JDM mani is for something else and the port on the throttle body is for the purge sensor. But then again the purge solenoid junk doesn't exist on the SIR-G
Old 02-07-2005, 12:52 AM   #6
Here are some pics to show the port on the throttlebody and also where I hooked up the EVAP Purge sensor
Old 02-07-2005, 12:55 AM   #7
FüK-VTEC
civicious's Avatar
Not the evap purge SENSOR, dude...the evap purge CANISTER...that canister thingie back on the firewall. There's suppsoed to be a funky orange nylon-ish braided hose that goes from that port on the TB to the CANISTER.
CMRA #265
AIM: greyfades
Old 02-07-2005, 12:59 AM   #8
Oh I see then it's probably different on the sir-g because the evap canister connects to the evap purge solenoid right there on top of the intake mani and the other port on the solenoid goes into the intake mani. My guess is theres a one way valve in that port on the TB?
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
