B20 on start up help please
Old 12-21-2007, 01:48 AM   #1
Rep Power: 0 tido316 is on a distinguished road
Default B20 on start up help please
hello members, i have a 91 EF std. got a b20 swap with CRX SI harness, LS matifold, b20 throttle body and injectors, distrubutor. running on PR4 ECU. My friend and i did the dpfi to mpfi wiring. Right now i have a problem where my motor fires up and it will shut off right away. on the ecu there was a code 10 but i replace the sensor and that went away and now is not throwing any codes at all, any luck or tips on what i should do? Thank you very much.
tido316 is offline   Reply With Quote
Old 12-21-2007, 02:09 AM   #2
AHHVTEC's Avatar
is there gas in the car
Old 12-21-2007, 02:11 AM   #3
yes there gas in the car i pump 2 gallon in there yesterday.
Old 12-21-2007, 03:00 AM   #4
Rep Power: 7 14 sec. windstar is on a distinguished road
well what i do is go through and make everything is wired right triple check everything... when you turn the key too acc your check engine light will light up for about 3 sec priming your fuel system? do you have enough spark? enough gas? did you mess with the timing at all? hook a fuel pressure guage up to see if you pump is pumping enough gas... could be fuel pump... could be alot of things can you give me more detail?
14 sec. windstar is offline   Reply With Quote
Old 12-21-2007, 03:06 AM   #5
you get the BRAKE
LS_VTEC's Avatar
Ride:  99 YZF-R6
Rep Power: 43 LS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to behold
sounds like a sensor or the such. you said it started, but wont hold an idle and shuts down... TPS? if it were that, it would throw a code. sooooo lets rule that one out... try spraying 2+2 into the throttle-body while moving the butterfly open and closed and have someone try and start it up. if it starts and runs than you my friend have a fuel problem. Make sure you wired everything right and not backwards, as well as your sensors.
eg hatch (jdm b16) sold
1999 Yamaha YZF R6 (modded)
http://hondaswap.com/engine-building...ow-pics-102486 sold
LS_VTEC is offline   Reply With Quote
Old 12-22-2007, 01:29 AM   #6
i have enought sparks, fuel i dont know because seems like fuel is being cut off as soon as it starts. but all i kno is the spark plugs smells like is dumped on fuel. i had a my frind gauge on their but he took it back the fuel was at 38 psi i tink but it slowly drops down. no i havent played the with the timming yet.
Old 12-22-2007, 01:31 AM   #7
yah i'm thinking about sensor too but do you tink you can go down the list wat sensors i need to change? right nowis not throwing any code at all that the wird thing before was code 10 but i change that sensor and no more code. by the way wat is the 2+2 spray and wat does that do.
Old 12-27-2007, 02:52 AM   #8
you get the BRAKE
LS_VTEC's Avatar
Ride:  99 YZF-R6
tps sensor (throttle position)
MAF sensor (mass air flow)
MAP sensor (reads vacuum on the tb)
make sure you didnt get them backwards, especially with your own wiring.
2+2 is a spray you can buy at an autoparts store. It is like fuel. you spray it in the throttle-body while opening and closing the butterfly and crank the engine. (this is usually done when an engine will not start and you are checking if its not getting fuel into the combustion chamber. usually it will start (if fuel is your problem), but it will not run very long...maybe a few seconds until the 2+2 burns up.
Have the l337's hAx0rEd me? (I need a code reader) klyph Computers, Games, Electronics etc 12 03-27-2007 07:47 PM
Car Won't Start HELP!! jaylo HYBRID -> EG-EK / DC 2 03-06-2007 07:47 PM
90 Accord w/ M/T won't start jeeva86 ECU's, Electronics, and Tuning 0 08-14-2005 12:36 AM
this weeks amazon.com deals pissedoffsol Members' Lounge 8 06-30-2005 06:25 AM
deals at Amazon.com pissedoffsol Members' Lounge 2 06-23-2005 12:33 AM
