I'm not very sure about this change, but here is the dum question and has anyone tried it before? I want to but a 92-95 vtec head on my ZC block both are D-series so it should work???? Is this something that works or not, I'm thinking of doing the ever so famous mini-me with a zc block, I'm planning on doing it the right way P28 and everything. So com'on guys waht do you think.
comments are welcome DA.Crespo san Juan, PR __________________
"If you only knew the power of the dark side of the Honda" |
Banned
this is a good question.....
can you put a vtec head on a dohc non vtec ZC engine? i was wondering the same thing. my initial guees is no, because isnt the ZC considered a part of the "d" series family? anyone? |
if its a sohc zc engine, then yes it can be done. its exactly like doing a mini me. but if it is dohc, it would not be worth it. it MIGHT be possible, and if it is it definitely wont be worth it.
#5 |
because there is no dohc vtec d series heads. all the heads that are dohc vtec are b, f, h, and k series and i think the piston spacing of the blocks are different. and trying to put a sohc vtec head on a dohc block would take too much time and money to make it work IF you could get it to work.
i dont think you could get either of these to work, but IF you did, it will cost too much and most likely not work very well. |
#6 | |
Banned
i know u cant match sohc and dohc... |
#7 |
i know you were talking about the dohc zc block. thats why i said you cant do it becasue zc is a d series, and there is no dohc vtec heads that are d seires
#8 | |
Banned
so what u are saying is that the dohc vtec head will not properly line up with the dohc zc block. |
#9 |
yes, the bolts wont match and i think the spacing of the cylinders and the combustion chambers are different and wont line up either.
#10 |
But wait, guys what if the block is from a ZC SOHC <_< would it work B) . I'm just not sure if anyone has done it before ZC SOHC block with a 92-95 vtec sohc cam head. It sounds kind of stupid but still lookingh for something that works before I can buy the big boy (B16B) so I guess it's going to be a while before I can buy that engine so I will try somthing new :P . Has anyone tried it before or is't a waste of money. Com'on guys don't let me down.
thanks __________________
#11 | |
#12 |
But does any one know for a fact that it's a good combination, does it actually work??? keep it coming or is it just a waste of time and money. And yes I was thinking of the B18C but the differnce in HP is 15. Now is'nt the b18 much more heavy than the b16 like 500 pounds difference??? So why go with a much heavier engine that only has 15 hp, just trying to undestand maybe I'n wrong but then again that's what this site is for informaiton
. But yes the b18c1 is a BADBOY I guess both are, atleast to me......thanks guys, DA.Crespo San Juan, PR __________________
#13 |
Its not much weight difference. Probably 10 lbs haha. Yeh 15 more hp but u also gotta look at the torque specs. b16a 111 lbs of tq vs 127-134 lbs of tq. SO just think about that. It makes alot of difference believe me.
#15 |
i dont think that they will differ in weight by even 10 lbs. they are the sam block, same size, only difference is the crank/rods/pistons.
#16 |
But theres a single cam zc vtec engine. I have a head for one at my shop. The block looks the same as the zc single without vtec. Not sure, but I would say most likely.
<u>I own </u> [b]2000 Gray Audi TT Quattro 2004 White/Blue GSXR 750 1981 Vw Caddy 1986 Yugo (yes yugo) |
#17 |
why dont u just do a normal mini me swap and forget about the zc block entirely? go find some shitbag 88-91 civic si and grab the block then go get yourself a nice y8 or z6 head.
i KNOW that will work__________________
<span style=\'color:gray\'>I get paid to read e-mail, and click links.</span> <a href=\'http://www.MikesPaid4Email.com/pages/index.php?refid=cointelpro\' target=\'_blank\'>SO CAN YOU!</a> |
