Facebook Twitter
cel code 7, 10, and 14
This is a discussion on cel code 7, 10, and 14 in the HYBRID -> ED-EF / DA forum
I have an ef with a b18a1 swapped in and now the timing is right i have all these codes being thrown. And the throttle response is so slow that i can have it floored before the engine catches up with it. Can anybody please ...
Old 02-04-2012, 02:11 PM   #1
Question cel code 7, 10, and 14
I have an ef with a b18a1 swapped in and now the timing is right i have all these codes being thrown. And the throttle response is so slow that i can have it floored before the engine catches up with it. Can anybody please tell me how to fix this problem Please help me.
masterfulmreric is offline   Reply With Quote
Old 02-06-2012, 11:02 AM   #2
jlicrx's Avatar
code 7 is for the TPS - probably why you have problem with throttle - was this a DPFI car converted to MPFI? - if so, were the wires switched on the TPS connector?
code 10 for Intake Air Temp and code 14 for Electronic Air Control Valve - usually when these codes show up together it means that the connectors are swapped - the IAT connector has 2-wires, one red with white stripe and one green with white stripe - the EACV connector also has 2 wires, one blue with yellow stripe and one black with yellow stripe - if the car was originally DPFI, the EACV connector is green in color - the IAT connector is white
ZCspeed Racing
Code 3 Map Sensor and Code 1 mhopkins10 Civic and del Sol - EG and EK 0 06-20-2010 03:15 PM
Hondata Code Issues - WTF No Code Limp Home Mode - Help? RubyCivic3 HYBRID -> ED-EF / DA 5 01-19-2009 08:36 PM
Code 19 Auto Tranny code on Manual Car? rfrumusa01 ECU's, Electronics, and Tuning 0 11-13-2007 09:46 PM
No KS code on P30 ECU Import R ECU's, Electronics, and Tuning 1 07-02-2004 09:11 AM
Integra Ls tranny code...(b18b1 tranny code) quickersilv3r HYBRID -> EG-EK / DC 2 04-01-2004 12:54 AM
© 2001-2011 HondaSwap.com
a SkeyMedia network site | Advertise on Hondaswap.com
