So i was racing this integra gsr (winning at that) mis shifted and went from the 3rd to 2nd. When it went into second it kicked it out of gear and my check engine light went on immediatley after. It also is really boggy until i get above 3k then it seems to run ok. I checked the code on the ecu (pr3) and it gave a code 1 or single flash. I put another pr3 ecu in the car and the check engine light came on before the car was even running so its not the ecu. I check the distributor out, it looks ok. Then the next day I took my fuel rail, intake manifold, o2's and shit out and checked them out and put them back in. I also had a spoon vtec controller that I took out to see if it was the problem too. I started the car and let it idle and the check light went away and it seemed fine. Then I left my shop and about 1 mile later the check light turned back on. it also started the boggy before 3k crap as well. Im lost here guys. I took it to my local speedshop and they dont know whats up either. Anyone had a similar experience or know anything I should check?
Current set up. 1991 civic hb dx standar. B16a engine. Skunk2 manifold. STR 70mm TB. Obx header custom made with 2 bungs for the dual o2's. aem coi. greddy exhaust. ![]() __________________
<u>I own </u> [b]2000 Gray Audi TT Quattro 2004 White/Blue GSXR 750 1981 Vw Caddy 1986 Yugo (yes yugo) |
I'll be back...
Ride: 06 Mazda 5, 91 Civic DX
well code 1 is o2 sensor and you just "checked" it out...try changing it...o2 will make you run f*cked up for the most part...
I will be moving to Avondale, AZ in June for 6 months to finish school. Hit me up if you're close to that area so we can chill... |
dizzy and fucked up fuel injectors will cause it also.
also check the wiring. __________________
91 STD Hatchback With OBD1 JDM Motor YS1 JDM tranny!!! PR3 OBD1 ECU and Dizzy TD-44U. 92-93 XSi **JDM** Stock Motor ECU and Engine Harness Converted to OBD1. Vtec Currently Working :O <a href=\'http://members.aol.com/megabighulk/Dyno1\' target=\'_blank\'>http://members.aol.com/megabighulk/Dyno1</a> My Dyno ^ |
#5 |
Bought a brand new dizzy. Its in the mail 189.00 on ebay WOOT. as for the injectors.... maybe ill have them tested.
#6 |
It almost sounds like you may have bent a valve. Throwing unburnt fuel into the exhaust stream can throw the 02 readings way off and possibly throw a code.
It's kinda farfetched, but a compression check is easy to do anyways, and since the problem seems to be related to the mis-shift, it's all I can think of. |
#8 |
Found problem. It was code 10 my bad! Was the IAC sensor. My was melted on the tip of the sensor. I must have backfired when i misshifted or something. I dunno but my cars running great NO MORE LIGHT AMEN!!!!!!!!!!!!!!!!!!!!!!! Hate that damn light grrrrrrrrrrr.
#11 |
sience were talking about codes, any one ever get a code 2(2 quick blinks)?
setup: crx dx, b16,pr3, dc header, aem intake. ive looked and cant find a code 2, it comes on sometimes driving regular but it doesnt make the car run funny or anything thanks -joseph |
| CRX / 88-91 Civic Hatch B16a swap timeslips? | The_MATRIX | Racing and Driving Techniques | 19 | 06-18-2007 03:56 AM |
| 98 civic - o2 sensor / check engine light | malone68 | General Tech and Maintenance | 9 | 07-28-2004 10:49 PM |
| engine check light | civicgRim_rIppeR | HYBRID -> EG-EK / DC | 1 | 03-19-2004 09:23 PM |
| Check engine light code 43 | Ractive78 | General Tech and Maintenance | 3 | 09-10-2003 06:51 PM |
| Engine Check Light. Obd1 | simonc | ECU's, Electronics, and Tuning | 1 | 01-17-2003 09:53 AM |
