Civic 1.6 si to crx dohc
Old 11-17-2003, 11:33 AM   #1
Rep Power: 15 '89civicSI is off the scale
I have a `89 civic 1.6 16v D16A6. This engine is replaced wiht a d16a9 from a ´89 crx. I used my own SI wiring on the d16a9. There are some difrences. The d16a9 has a sensor less on the pgmfi intake. The crx engine doesnt have a catalatic conferter and therefor also no sensor on the outtake. Also is there some diffrence in the vacuum hoses.
I have rewired the cam angle sensor. The car runs fine but at stationaire drive the rpm is between 900 and 1500 and goes up and down. So my question do i have to do some more rewirring or must i find the problem somewere else
==Bye SI Hello DOHC.==
'89civicSI is offline   Reply With Quote
Old 11-17-2003, 12:11 PM   #2
90 Integra Sedan
B20V 225 / 153
Old 11-19-2003, 04:09 AM   #3
Anyone?
Old 11-19-2003, 04:15 AM   #4
Rep Power: 44 MaaseyRacer is an unknown quantity at this point
Send a message via AIM to MaaseyRacer
Dude don't be so quick to call someone a mother fucker, I am getting sick of everyone looking for an excuse to use that emoticon. Be helpful what is the point of posting if you are just going to say that leave it alone, or as the person to clarify something.
Now to answer the question:
Are you throwing any codes? Check your PCV valve, and you intake manifold sensors. I have a slightly irractic idle on my 89 Civic DX ever since I did a MPFI swap. As far as I know you should not have any left over sensors in the swap. Also The D16a9 and the D16a6 both came on cars that had cat. converters. Double check your Vaccum lines and your wiring, you might be missing something.
Good Luck
2004 Toyota Tacoma
3.4L V6
TRD Package
4WD
MaaseyRacer is offline   Reply With Quote
Old 11-25-2003, 07:14 AM   #5
The d16a9 dint had a cat. converters i am certain of that. Its an european car. And yes the d16a9 has a sensor less on the pgmfi. After reseting the ecu the rpm is not good. Before resetting the ecu it ran fine but now...
Old 11-25-2003, 09:49 AM   #6
jlicrx's Avatar
the sensor left over is probably the fast idle control solenoid which was on back of the intake manifold on the Si and is not used on the A9 - the only wiring changes you needed to make were the 2 wires to the cylinder position sensor on the end of the exhaust camshaft - if you are not getting a check engine light for the oxygen sensor, don't worry about it (are you using the Si ECU?) - the vacuum line routing for the A9 should be the same as the Si - fluctuating idle can be from several things, vacuum leak, malfunctioning EACV, low coolant level or bad coolant temperature sensor are the likely causes.
ZCspeed Racing
Old 11-25-2003, 11:03 AM   #7
Her are the vacuum line pics of my old engine and the new one. You can see that the d16a6 has an canister that the d16a9 doesnt have. After cheking everything mij ecu gives the faulty codes 11 and 17. Also my cooling fan doesnt work anymore. I used my new dohc ecu.
These pictures are from this site where other manuals can be found.
http://www.icelord.net/honda/repair/
Old 12-02-2003, 01:25 PM   #8
anyone?
Old 12-02-2003, 11:08 PM   #9
jlicrx's Avatar
you could just get rid of the purge cannister and connect it like the A9 diagram - the purge cannister is just a receptacle for fuel vapors to keep them from escaping into the atmosphere - doesn't affect how the engine runs and doesn't cause CEL codes - one of the lines to the cannister is a vent from the fuel tank - you could also swap the throttle body from the A6 onto the A9 and then connect it like the A6 - from looking at the diagrams, it appears that the only difference is the large (usually red) cloth braided covered line from the top center of the throttle body to the cannister - don't know what code 11 is? - code 17 is the VSS or vehicle speed sensor which is on the gauge cluster where the speedometer cable connects - does your speedometer work? cooling fan is controlled by temp sensor in the back of the block next to the oil filter - is this hooked up?
ZCspeed Racing
FS: Civic, Integra, and aftermarket parts b18ctrb Parts: For Sale/Trade/Wanted 6 12-04-2007 04:23 PM
ALL CIVIC PARTS MUST GO ddubz712 Parts: For Sale/Trade/Wanted 12 11-10-2006 12:29 PM
Anyone here? 2000Si Members' Lounge 14 12-09-2003 11:55 AM
'92 Civic 4dr D15b7 Into 88-91 Civic 4dr Venom800TT HYBRID -> ED-EF / DA 1 05-31-2003 11:18 PM
Chassis Code VSMB16A2 General Tech and Maintenance 10 01-22-2003 05:32 PM
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
