clutch cable ?
Old 09-12-2009, 11:48 PM   #1
kricket3000's Avatar
Rep Power: 8 kricket3000 is on a distinguished road
Default clutch cable ?
i'm swapping a b18a1 into my 88 crx hf, can i use the crx clutch cable or do i need one from a da? thanx bob
kricket3000 is offline   Reply With Quote
Old 09-13-2009, 12:26 AM   #2
D16SiHatch's Avatar
Rep Power: 33 D16SiHatch has much to be proud ofD16SiHatch has much to be proud ofD16SiHatch has much to be proud ofD16SiHatch has much to be proud ofD16SiHatch has much to be proud ofD16SiHatch has much to be proud ofD16SiHatch has much to be proud of
you're supposed to use the stock crx cable. so no you don't need to get one from a da
91 Civic Si
b18b1, I/H/E, 6000k HID kit, 94 teg cluster
Parting mustang out to buy another civic
D16SiHatch is offline   Reply With Quote
Old 09-13-2009, 01:05 PM   #3
i have tried and tried and it just will not fit, it's not long enough between the top bracket and the shift fork, any ideas?
Old 09-13-2009, 06:37 PM   #4
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
Rep Power: 214 INJEN78 has a reputation beyond repute
INJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond repute
adjust the cable all the way out..put the cable on the bottom of the fork..now pull up and put the tightener onto the bracket..make sure you adjust the cable all the way out before doing so..
R.I.P BEN LEE2/24/08 we love and miss you
http://burnoutbox.activeboard.com/in...BID=127652&p=1
GOOD FAST CHEAP,
you can pick only two.
fast and cheap isn't good
good and cheap isn't fast
good and fast isn't cheap
Old 09-13-2009, 08:51 PM   #5
i have and i push on the pedal and it won't move cause the fork is all the way up, it's like i'm going to break the cable.
Old 09-13-2009, 09:15 PM   #6
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
is the bracket upside down????
can you get pix?
GOOD FAST CHEAP,
Old 09-13-2009, 10:00 PM   #7
Here is the pictures. Any ideas?
Old 09-13-2009, 10:27 PM   #8
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
the bracket looks bent back and up...
but if not..try unbolting the bracket.putting the lower piece on then rebolt it up..
you cant pull the clutch arm up anymore?
GOOD FAST CHEAP,
Old 09-13-2009, 10:35 PM   #9
D16SiHatch's Avatar
i'm not sure if the bracket is bent at all... but the clutch arm should definitely move up enough to allow you to slide the cable in.
91 Civic Si
Old 09-13-2009, 10:37 PM   #10
!!YTINASNI
phyregod's Avatar
Ride:  '06 Element , '07 CBR 1000rr, '91 CRX, '98 jeep GC 4x4
Rep Power: 413 phyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond repute
phyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond repute
myspace
I'd bet money that the little holder fell out of the firewall. Put it back in, lock it into place, and everything should fit just fine.
aleaf.CRX: I've never had steering this bad on a vehicle before. I'm afraid it's going to jump in the other lane and attack someone
reckedracing: PIIDB for jesus
Old 09-13-2009, 10:39 PM   #11
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
totally forgot about that^ good idea..
and yes the arm should def. move up..like posted above
GOOD FAST CHEAP,
Old 09-13-2009, 10:52 PM   #12
i have tryed that and still it's really tight and it won't let it release down, and everything at fire wall and pedal are good.
Old 09-13-2009, 10:57 PM   #13
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
then its gotta be the bracket..
GOOD FAST CHEAP,
Old 09-13-2009, 11:04 PM   #14
were does the cable hook to the shift fork on top of the bell looking thing, on it or below it? it's like the cable is not long enough. the bracket is the same one that came out the DA
Old 09-13-2009, 11:06 PM   #15
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
the bell looking thing goes up under the fork part
GOOD FAST CHEAP,
Old 09-13-2009, 11:35 PM   #16
well reseaching some people said they used one from a DA???? i don't know what else to try, does any one have a pic of it installed?
Old 09-13-2009, 11:42 PM   #17
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
i used the cable from my 91 hatch when i did my ls...i also used the cable from my 91 crx when i did the ls in that..ill try to get pix from my boy who has the same swap
GOOD FAST CHEAP,
Old 09-13-2009, 11:46 PM   #18
cool man that would be great, also it's an 88 and a HF so everything always seems to be different for some reason?????
Old 09-13-2009, 11:49 PM   #19
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
yea but the clutch cable is the same as any other model and year..i dont get what the problem is..
well i get the problem lol..i dont know why though
GOOD FAST CHEAP,
Old 09-13-2009, 11:55 PM   #20
that makes two of us lol, maybe i'll try one from a DA, i don't know what else to do
Old 09-13-2009, 11:56 PM   #21
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
eh you could give it a shot..maybe try getting another bracket to compare yours with?
GOOD FAST CHEAP,
Old 09-14-2009, 12:40 AM   #22
D16SiHatch's Avatar
so even if you lift up the clutch arm it doesn't fit? it looks like it should.. i'm not sure what the problem is either.
91 Civic Si
Old 09-14-2009, 08:42 AM   #23
it fits but won't drop back down, it keeps the fork all the way up and i push on the pedal it won't move towards the floor at all.
Old 09-15-2009, 03:37 PM   #24
D16SiHatch's Avatar
maybe there's something wrong with the clutch?
because the arm is not supposed to drop back down once the cable is in place. you're supposed to tighten the cable till you can feel it start to get tight. this would indicate the throwout bearing has just begun to touch the fingers on the pressure plate. so if you cannot press the pedal down at all then either the cable is binding somehow, or the there is something wrong with the clutch assembly.
91 Civic Si
Old 09-15-2009, 03:43 PM   #25
i have pulled up on the arm but not real hard, when i get home i'll try to pull harder -- thanks for hanging with me guys!
Clutch cable help .. Cable to Hydro Integra BonesZ33 HYBRID -> ED-EF / DA 41 10-21-2009 11:13 AM
hydrolic clutch to cable clutch??????? mikester1222 Civic and del Sol - EG and EK 3 03-03-2008 12:51 PM
hydrolic clutch to cable clutch mikester1222 HYBRID -> EG-EK / DC 10 10-20-2007 02:31 PM
WTB: Integra clutch cable bracket and integra throttle cable ExplicitSnow Parts: For Sale/Trade/Wanted 1 11-10-2006 06:29 PM
