Facebook Twitter
codes
This is a discussion on codes in the HYBRID -> ED-EF / DA forum
my friends 88 civic dx is flashing code code 5 then a split second later it flashes 2 then pauses then flashes code 20....
Old 10-03-2003, 10:48 AM   #1
civichbwithb18a1 is offline   Reply With Quote
Old 10-03-2003, 02:24 PM   #2
Code System
Code 1 (1 flash) Oxygen content
Code 3 or 5 Manifold absolute pressure
Code 4 (4 flashes) Crank angle sensor
Code 6 (6 flashes) Coolant temperature
Code 7 (7 flashes) Throttle angle
Code 8 (8 flashes) TDC position (top dead center) timing
Code 9 (9 flashes) No. 1 cylinder position (1.6L)
Code 10 (10 flashes) Intake air temperature
Code 12(12 flashes) No code 11 don't know why. Exhaust gas recirculation system
Code 13 (13 flashes) Atmospheric pressure
Code 14 (14 flashes) Electronic air control (EACV)
Code 15 (15 flashes) Ignition output signal
Code 16 (16 flashes) Fuel injector
Code 17 (17flashes) Vehicle speed sensor
Code 19 (19 flashes) No code 18 for some reason Lock up control solenoid valve
Code 20 (20 flashes) Electric Load
mellowboy is offline   Reply With Quote
88+ ECU Error Codes pissedoffsol Reference Materials 1 05-19-2005 12:03 PM
What is going wrong? Can't figger out codes... wiredjosh HYBRID -> EG-EK / DC 6 07-12-2004 05:13 PM
Error codes 20 & 41 & egr & fis sensor - need help HONDAPITSTOP HYBRID -> BA-BB /CA-CD 8 03-17-2004 09:03 PM
By-passing ECU codes peanut ECU's, Electronics, and Tuning 13 01-07-2004 02:48 PM
Error Codes timEspeed ECU's, Electronics, and Tuning 11 11-11-2003 06:05 AM
© 2001-2013 HondaSwap.com
